I am wondering if there is a recomended oils to use in the diffs tranny and transfer case I like a few oils works well but dont know if they are good for my rig.
Our Nation is Great because it is Full of Good. If we remove the Good we no longer have a Great Nation
I just use whatever dino 75w90 I find.. I'd only recommend synthetic if you dont plan on changing it for another 60k miles... but other than that, just get the cheap stuff and change it once a year or so...
2001 Discovery II | 2006 LR3 HSE7 | 1994 Defender 90 #416 (Gone)
Mods: Oil Pressure Gauge, ScanGaugeII, CDL, Electric CDL Actuator, RoverRacks Rear ladder, Limb Risers, ToddCo Front Drive Shaft, DI Wiper Arms, G4 Upper Rear Lamp Guards, No Amigos since 11/09
Coming soon: Install Greg Davis rear bumper, Replace 4 ball joints, Replace belt tensioners and pulleys.
For the future: .... wait and see....
I use the same oils as Josh with great results. The heavier gear oil gives better wear protection and allows the diffs and t/case to run cooler and quieter.
Jamie, Do you know how to do a drain and fill on a D2 tranny, if not shout.
Did you run any temperature recorders after the switch to 140 ? I did some testing and found the 140 ran about 20 to 30 C warmer in the transfer case and about +10 in the axles, i have found lowest temp with 75W90.
That kind of sounds counter-intuitive. Was your OAT for both tests exactly the same? Did you run the same brand before/after? Synthetic/Non-Synthetic before/after? Rig loaded the same before/after? Same course before/after? Same driving time before/after? See a pattern here? What I'm saying is that there are a lot of variables. I don't know if I'd jump to the conclusion that a lighter weight oil runs cooler unless I was absolutely sure that the before and after variables were taken out of the equation.
MTCW - Bill
Yes same conditions, oil used for the test was Caterpillar (Mobil) I did the test a few years ago on a Defender 110 CSW and have stuck with 75w90 since. I recently picked up a D2 and have just changed all of the oils, i have fresh temperature recorders in place and should have some max temperatures after my first road trip later this month, i will post the results.
Alex
Thicker oil will tend to run a bit warmer in anything. The +10cC in the diffs is neither here or there. The thicker oil will offer a lot better protection. However, I would not use 85/140 in the transfer case. Too thick to get into all the areas that it needs to.
A lot of shops here in the states suggest it, especially on high mileage units for the wear protection as well as the noise reduction.
