» Sponsors
» Sponsors
Old 01-07-2009, 08:39 AM   #1 (permalink)
Default One Airbag Problem
After the DII HSE was lifted with a jack on the rear passenger side that corner airbag now does not hold its level at all times while the other rear airshock operates correctly. No fault codes are present. Is there a process for trying to fit the airbag back in proper fitting place so it works properly. Trying to trouble shoot before replacing and save some $$$$. Thanks.
Champ is offline   Reply With Quote
Old 01-07-2009, 10:45 AM   #2 (permalink)
Super Moderator
How many miles on your truck? If the bags are getting brittle, you may have cracked one by an improper lift.
Send me your tele number and I will call you and walk you thru what to do or check.
rr v8 4.4 nikasil problem???? please help. 2002hse Range Rover P38, Mk III and Range Rover Sport 3 09-12-2009 05:37 PM
Freelander 2002 airbag problem. reubenb04 Freelander / LR2 3 10-05-2008 05:19 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 04:50 AM
rr v8 4.4 nikasil problem???? please help. 2002hse General Land Rover Discussion 4 10-19-2005 02:00 PM
Intermittent Driveline Vibration at 60MPH AdrianL Range Rover Classic 10 06-24-2005 08:52 AM
