Old 05-11-2006, 02:05 PM   #1 (permalink)
LANDY96's Avatar
Default One flash when locking/should be three!
I just bought a 99 DII. I noticed when I lock it, it only flashes one time. From the manual it should flash three times. Also a few minutes after I lock it sometimes the lights flash, as if the hazards are on? Nothing in the manual about that. It do think the batter is low, as I have to be quite close to the vehicle for the button to work. The light on the dash also flashes rapidly, and from the manual it denotes a low battery. So do you think the above problems are also from the low battery?
When the battery is low on my DI, the exterior lights don't flash at all, and the interior lights don't come on.
Eric The Red
93 Range Rover Classic
96 DISCO SE7 5-SPEED SOLD
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
Old 05-11-2006, 02:22 PM   #2 (permalink)
I'll check mine...i think mine only flashes once when locking???? i know the dash warning LED for the alarm to show that it is armed flashes very fast.....know you got me thinking....
6cuda6 is offline   Reply With Quote
Old 05-11-2006, 03:17 PM   #3 (permalink)
I believe my 99 DII only flashes once also. I have also noted it flashing rapidly after being set sometimes and I know it is not a low battery cause I run dual batterys.
Old 05-11-2006, 03:21 PM   #4 (permalink)
I just checked mine...only flashes once as well...LED on dash flashes slows after 10 seconds like it's suppose too..... don't know myself know?? any one else???
Old 05-11-2006, 04:34 PM   #5 (permalink)
LANDY96's Avatar
To clarify further, I was refering to the remote battery, not the truck battery! I will change this tonight if I can, perhaps that will solve or narrow things!
Eric The Red
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
Old 05-11-2006, 05:09 PM   #6 (permalink)
Otherwise known as STEVE
If you press the lock button twice, it should 'superlock' the truck and the truck will flash three times.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 05-12-2006, 09:37 AM   #7 (permalink)
LANDY96's Avatar
I may have an explanation! I had the windows down when I locked the truck! I put the windows up when I got home, and locked it "once" the lights flashed "once" and the truck did not flash "hazard-like" afterwards!
Eric The Red
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
Old 05-12-2006, 02:06 PM   #8 (permalink)
strange- mine honks the horn when all the zones aren't secure when locking.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
Old 05-12-2006, 02:31 PM   #9 (permalink)
LANDY96's Avatar
I suppose I should have put a ? But I did read that about the truck honking if the zones were not set. So yeah, still confused! The "superlock" works ok. Lights flash "3" times.
Eric The Red
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
