Oxygen sensor replacement? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 11 (permalink) Old 08-01-2011, 08:25 AM Thread Starter
Life is Good. Life with a Rover is Better.
LeninG.'s Avatar
Quoted: 0 Post(s)
Garage
Is replacing the sensors an easy job or is it something I should take to a mechanic to do? If i can do it, where should I start?
LeninG. is offline
post #2 of 11 (permalink) Old 08-01-2011, 12:12 PM
Quoted: 0 Post(s)
its easy enough...youll get dirty..but its not that bad... For the sensors that are pre cat they are easier to unplug if you go through the engine bay but then unscrew them from underneath the car... the post cat ones are super easy to get to and replace. I did it in 30 minutes in the dark so its not bad at all. you can get the sensors at your local autoparts store..i think they are BOSCH. they get pricey if you are going to do all of them so make sure you know which ones are actually broken as to save money.
2004 Discovery II, Rebuilt Front Driveshaft, Maglites, STI wires, Bosch Plugs, DBA Rotors, Terrafirma 3in. Lift, Random linkages and rods, custom sliders, custom front bumper, 33 in. BFG KM2's, Safari Snorkel, converted to old style glass headlights, tool kit, etc...
Belafontainw is offline
post #3 of 11 (permalink) Old 08-01-2011, 12:31 PM
Quoted: 1 Post(s)
Unplugging those front sensors really suck, I think it is easier to remove the engine than unplug those suckers.
Bosbefok is offline
post #4 of 11 (permalink) Old 08-01-2011, 12:34 PM
Administrator
Quoted: 5 Post(s)
Why are you replacing them, do you have fault codes, are you replacing all 4, how many miles on your truck?
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #5 of 11 (permalink) Old 08-01-2011, 04:13 PM
helievacpilot's Avatar
Quoted: 35 Post(s)
Some helpful hints: 1. Don't go half-assed on the sensors. Pay a little more and get OEM from AB for instance. D2's are sensitive to cheapies. 2. If you replace one, make sure you replace it's opposite. If you can swing it, replace all four. 3. To get the old ones out, soak them in penetrant the night before, cut the wire and get a box end on them to avoid stripping the nut. 4. There is a trick to the plug. If you just pull on it, it will not come unplugged. The entire plug assembly (both sides connected) is attached to the vehicle via small metal tabs. You must first remove the connected plugs from this metal tab and then the connectors will come apart.
- Bill
helievacpilot is offline
post #6 of 11 (permalink) Old 08-01-2011, 09:50 PM
Keanan's Avatar
Quoted: 0 Post(s)
What's the reason for wanting to replace the O2 sensors?
Keanan is offline
post #7 of 11 (permalink) Old 08-02-2011, 04:55 PM Thread Starter
LeninG.'s Avatar
Quoted: 0 Post(s)
Garage
I was told that the rear ones are bad by a mechanic, but I wanted to replace them myself. And My Disco has 125,000 miles, thanx for the advice helievacpilot. Do you suggest anything else Disco Mike?
LeninG. is offline
post #8 of 11 (permalink) Old 08-02-2011, 05:23 PM Thread Starter
LeninG.'s Avatar
Quoted: 0 Post(s)
Garage
where do i find the rear sensors???
where are the rear sensors exactly???
LeninG. is offline
post #9 of 11 (permalink) Old 08-04-2011, 03:58 AM
Quoted: 35 Post(s)
They're located after the CAT's on top of the pipes.
- Bill
post #10 of 11 (permalink) Old 08-04-2011, 09:09 AM
'03 Disco SE
Bosnian Discovery's Avatar
Quoted: 12 Post(s)
Just did this myself. Go to Autozone/Advance to get the codes read to make sure you are doing the right thing (if you don't have a code reader yourself). If your rear sensors are shot then you'll get codes saying there are faults with 'bank 1 sensor 2' and 'bank 2 sensor 2'. You didn't mention if you had a SES light lit.
Replacement is SUPER easy - even for beginners. The truck sits nice and high so you don't even need jacks or anything. Follow the exhaust headers as they leave both cylinder banks, the headers will then converge into 1 pipe and then feed into catalytic converters (look like small mufflers), directly after the catalytic converter you'll notice 2 sensors on TOP of the exhaust pipes (1 in each). Follow the wires coming off of the top of the sensors and they'll lead you to the plugs somewhere above the exhaust pipes and frame rails. CAREFULLY unclip the plugs - do NOT force it, you risk messing up the wiring if pins come loose from the plugs, it should come out easily. Then simply take a wrench and carefully remove and replace the sensors. Even the most inexperienced mechanic shouldn't take more than 1 hour to do this. I finished in about 15 minutes per side.
OEM is BOSCH and please for your sake do use them. Someone had replaced my pass. rear sensor with some cheapie piece of crap which was probably dead from the very start.
Let us know if you need more help.
Bosnian Discovery is offline
post #11 of 11 (permalink) Old 08-04-2011, 12:43 PM Thread Starter
LeninG.'s Avatar
Quoted: 0 Post(s)
Garage
Thanks for all the support!
Im not getting any SES lights on but an independent landrover mechanic told me that the rear ones are out so i figured I replace them myself. Thanks for all your support guys!!!!!!!!!!!!!!
LeninG. is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Oxygen Sensor replacement - 1991 Range Rover glenncof Range Rover Classic 3 10-15-2010 04:44 AM
o2 oxygen sensor marchon4life Discovery Series II 2 03-29-2010 03:52 PM
Oxygen Sensor Replacement - Help jbf Discovery Series II 7 10-22-2009 08:29 PM
Oxygen Sensor(s) MysteryTheatre Range Rover Classic 14 03-20-2008 02:47 PM
oxygen sensor scotth Discovery Series II 2 09-02-2005 06:12 PM
You may post new threads
You may post replies
