Old 09-16-2005, 11:49 AM   #1 (permalink)
Default Oxygen Sensors
I have a bad O2 sensor is their any way of finding out which one it is and are they easy to change.
thanks
flyforpeanuts is offline   Reply With Quote
Old 09-16-2005, 12:30 PM   #2 (permalink)
4x4 Adventure Gear
John C's Avatar
How do you know if you have a bad O2 sensor?
You can use an OBDII scanner to determine which of the four O2 sensors is bad.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 09-16-2005, 12:32 PM   #3 (permalink)
John
Is this scanner only availabe at dealers?
Old 09-16-2005, 12:56 PM   #4 (permalink)
4x4 Adventure Gear
John C's Avatar
No, you can purchase one for as low as 0 bucks. The better ones go for 100 and up. I purchased one from AutoZone and it works fine, even resets the codes for you.
You can go to AutoZone and they will read the codes for you for free, no need to go to the dealer.
You can get sensors from Nathan Crabtree (http://www.discountbritishparts.com/) for a bit over 100 $
Good luck.
John C
