Old 10-11-2007, 08:55 PM   #1 (permalink)
Default P0332
I'm getting a P0332 code, I think it's a knock sensor code.
Running 91 octane... it doesn't turn the SES light on, but i'd like to get rid of it... any suggestions?
99 disco ii w/ cold climate and SLS.
plastic is offline   Reply With Quote
Old 10-12-2007, 04:48 PM   #2 (permalink)
DiscoAmigo's Avatar
From the RAVE
Should a malfunction of the component occur the following fault codes may be evident and can be retrieved by
TestBook:
P0332 Knock sensor 2 circuit low input (bank 2) RH bank signal less than threshold determined from
ECM model above 2200 rev/min
in other words, replace the knock sensor
2001 Discovery II
DiscoAmigo is offline   Reply With Quote
Old 10-16-2007, 08:38 AM   #3 (permalink)
troverman's Avatar
I wouldn't replace the sensor unless SES illuminates. For SES to illuminate, per OBDII standards, the fault must occur 4 times in a row to become hard and light the MIL (SES). It may be an intermittent problem.
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rovers:
1995 Range Rover 4.0SE
Old 10-16-2007, 01:32 PM   #4 (permalink)
Why not swap the sensors and see if the code follows ?
buick215 is offline   Reply With Quote
Old 10-18-2007, 06:34 PM   #5 (permalink)
check the wiring to the sensor.
seen a few harnesses at the sensor go.
but remember to torque the sensor to spec or else it can pick up every spark and everything else as well.
