Passanger seat motor does not work - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 16 (permalink) Old 03-10-2010, 11:49 AM Thread Starter
Quoted: 0 Post(s)
Do I need to remove the seat to replace the motor? The motor that will not work is the front to back motor. Also, the heated seat light illuminates on both the drivers and passangers side. I have one replacement pad that works that I wanted to test but for the life of me I can't find the connection on the seats. THanks
SH
2000 D-II - 160,000 miles
Spiderhole is offline
post #2 of 16 (permalink) Old 03-10-2010, 11:55 AM
Administrator
Quoted: 5 Post(s)
How do you know the motor is bad, usually the switch fails, have you tested for power to the motor?
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #3 of 16 (permalink) Old 03-10-2010, 12:24 PM Thread Starter
Quoted: 0 Post(s)
I haven't really tested it, but the reason I think this is when I push the switch forward the seat acts like it wants to go forward, motor clicks for a second. I think the signal is getting there, but I can't confirm 100%.
post #4 of 16 (permalink) Old 03-10-2010, 03:06 PM
Quoted: 0 Post(s)
I have the exact same problem...feel it click but no movement......subscribed!
bcsellie is offline
post #5 of 16 (permalink) Old 03-10-2010, 03:10 PM
Quoted: 0 Post(s)
My passenger seat does the same thing. It moves every way except back and forth. Is is the switch? The dealership I bought it from (BVLR) told me the passenger seat is not supposed to go back and forth.
EzRyda420 is offline
post #6 of 16 (permalink) Old 03-10-2010, 04:14 PM
jrockett's Avatar
Quoted: 0 Post(s)
The passenger seat on my 03 blows the fuse that controls the forward/backward movement. I bought a pack of fuses at the local auto zone for an easy fix. I've only had to replace three of them over the course of a year and a half.
jrockett is offline
post #7 of 16 (permalink) Old 03-10-2010, 04:22 PM
hafaday's Avatar
Quoted: 0 Post(s)
that's bull. the seats go all directions, except left and right of course
01 d2
Bill H.
The Rave on pdf's.
hafaday is offline
post #8 of 16 (permalink) Old 03-10-2010, 05:50 PM
hafaday's Avatar
Quoted: 0 Post(s)
SH
looking at Rave (hard to decipher) but it looks like there should be two different wire looms that run from the bottom of the seat, up to the seat back. these wire looms look to be located inboard (console side) of the seat at the rear.
i looked at mine, and all though i have the heater buttons. it looks like i do not have the elements in there, which would explain why they don't work.... but, i wouldn't use them any way. already got a hot ass............ just kidding........
to find this, tilt the seat, front down and rear up.
USER DISCRETION ADVISED
you said that you have a spare element? try matching up the connectors and see what happens..
good luck
01 d2
Bill H.
The Rave on pdf's.
hafaday is offline
post #9 of 16 (permalink) Old 03-10-2010, 07:30 PM Thread Starter
Quoted: 0 Post(s)
I have checked all the fuses under the seat and elsewhere. They all appear to be a-ok unless I'm missing something. I am still curious, say it is the motor after I test the switch... do I have to pull the seat out to replace it?
I will move the seat forward to check for the heating elements. The switch lights so I guess powers getting to it, but if its supplying power to an element I don't know. I bet I'll be pulling the center console again.
post #10 of 16 (permalink) Old 03-11-2010, 01:53 PM Thread Starter
Quoted: 0 Post(s)
Sorry to bump this, but I am really curious, do I have to pull the whole seat if the motor is the issue?
post #11 of 16 (permalink) Old 03-15-2010, 01:41 PM
Quoted: 0 Post(s)
did you ever figure this out? just curious, because because my passenger seat in my '00 DII goes every which way except fwd and back. however, i dont get any noise or click when i engage the switch. checked all the fuses and they are good. i was hoping you may have gotten it figured out so i knew what kind of job i was getting into.
resqguy77 is offline
post #12 of 16 (permalink) Old 03-15-2010, 01:59 PM
OBauer809's Avatar
Quoted: 0 Post(s)
Same problem happened to me a few months ago. I unplugged the relay and fuses from under the seat and then back in again... and all was well.
If thats not the case, definitely see if the switch is getting power, and if the motor is getting power to narrow it down.
Oliver
2001 Discovery II - 3" Rovertym/OME lift, 2 KC's, 4 IPF's, modified custom front & rear bumpers, ARB diff-guards, skids.
OBauer809 is offline
post #13 of 16 (permalink) Old 03-21-2010, 07:47 AM Thread Starter
Quoted: 0 Post(s)
Sorry, I took on some other things in the meantime. I still haven't determined if the seat would have to come out to replace the motor. I plan on takling this next.
post #14 of 16 (permalink) Old 03-21-2010, 08:10 AM
hafaday's Avatar
Quoted: 0 Post(s)
yes, you gotta remove the seat.
01 d2
Bill H.
The Rave on pdf's.
hafaday is offline
post #15 of 16 (permalink) Old 03-21-2010, 07:17 PM Thread Starter
Quoted: 0 Post(s)
Land rover must have gotten a real good deal on the actuators for these vehichles. So far, I've had fail, or replaced these motors: heather/ac blower, rear door lock, front sun roof, wipers, passanger seat.
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Passenger seat wont Work ? LoWBuDget RoVer Discovery Series I 4 12-01-2009 04:10 AM
Front passenger seat does not work DougG Range Rover P38, Mk III and Range Rover Sport 0 09-25-2009 05:54 AM
wipers on the passanger side dragan Discovery 3 / LR3 5 12-12-2008 05:50 AM
rear seat locks? won't work....help das Range Rover Classic 0 11-16-2006 06:34 AM
Need help replacing passanger mirror '98 monoverb Discovery Series I 1 01-19-2005 07:52 AM
You may post new threads
You may post replies
