Persistent misfire after layup - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 4 (permalink) Old 08-26-2011, 05:43 PM Thread Starter
Quoted: 0 Post(s)
2002 4.0 litre Disco 2, cats and SAI.
Low speed misfire, codes indicate multiple cylinders but 4 and 7 seem to be prevalent.
I would like to seek some opinions on my next move to resolve the problem.
Some background which may assist. Vehicle unexpectedly laid up for an extended period (2+ years) in rural Thailand. Apparently one of the relatives put a battery on it and tried to start it without success after failing to check all was OK. A lot of rodent damage to wiring beneath engine compartment fuse box and odd damage elsewhere now repaired. Coils changed, MAF substituted for a known good one, plugs and leads were renewed by the stealer shortly before the layup (factory items). Injectors replaced with new whilst changing the coils as I had a spare set available. (Also SLS compressor repaired – see my other post for details which may help someone else.)
Vehicle now up and running and able to move it to civilisation. Ran OK at around 2500rpm for the 600km journey but misfire on tickover seems to be getting worse. Fuel consumption fairly normal but occasionally short on acceleration.
Have ordered some Bosch 4 electrode plugs for a start but wondering whether to replace the recently renewed factory leads too. Thinking that I will have a compression test done whilst replacing the plugs.
Any ideas would be most welcome!
Current codes logged:
THE MOTRONIC FAULT CODE MEMORY CONTAINS CODES FOR THE FOLLOWING CURRENT FAULTS -:
P1300 = CATALYST DAMAGING MISFIRE MULTIPLE CYLINDERS DRIVE CYCLE C, WHICH HAS OCCURED 237 TIMES
(SIGNAL TOO HIGH, THE FAULT IS CURRENTLY PRESENT, THIS FAULT CAUSES MIL LAMP ACTIVATION, THE FAULT HAS BEEN DETERMINED AS INTERMITTENT).
P0304 = CATALYST DAMAGING MISFIRE CYL 4 DRIVE CYCLE C, WHICH HAS OCCURED 237 TIMES
P0302 = CATALYST DAMAGING MISFIRE CYL 2 DRIVE CYCLE C, WHICH HAS OCCURED 152 TIMES
P0300 = EMISSION RELEVANT MISFIRE MULTIPLE CYLINDERS DRIVE CYCLE C, WHICH HAS OCCURED ONCE
(SIGNAL TOO HIGH, THE FAULT IS CURRENTLY PRESENT, THIS FAULT CAUSES MIL LAMP ACTIVATION, THE FAULT HAS BEEN DETERMINED AS PERSISTENTLY PRESENT).
P1000 = EMISSION RELEVANT MISFIRE CYLINDER 4 DRIVE CYCLE C, WHICH HAS OCCURED ONCE
P1000 = EMISSION RELEVANT MISFIRE CYLINDER 2 DRIVE CYCLE C, WHICH HAS OCCURED ONCE
P0307 = EMISSION RELEVANT MISFIRE CYLINDER 7 DRIVE CYCLE C, WHICH HAS OCCURED ONCE
P1000 = CATALYST DAMAGING MISFIRE CYL 7 DRIVE CYCLE C, WHICH HAS OCCURED 194 TIMES
Expatdavid is offline
post #2 of 4 (permalink) Old 08-27-2011, 05:56 AM
Administrator
Quoted: 5 Post(s)
Don't know where you are located but if I can call you I may be able to walk you thru some on this stuff.
In the mean time, go get all your codes cleared and see what comes back.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #3 of 4 (permalink) Old 08-27-2011, 10:21 AM Thread Starter
Quoted: 0 Post(s)
Mike, thanks. I'm in Bangkok where nowadays parts seem to be getting very expensive so waiting for the plugs and a new set of leads from the UK. Thanks too for the offer of a chat.
Maybe the best way to do that would be for me to call you on Skype if you have a username? We are 6 hours ahead of GMT here which I guess means around 13 hours ahead of you. I cleared all the codes before my trip to Bangkok but will clear them again in the morning and go for a short drive to see what comes up again.
I will post them tomorrow. Thanks again.
post #4 of 4 (permalink) Old 08-28-2011, 09:55 PM Thread Starter
Quoted: 0 Post(s)
Mike,
Here are the "new" fault codes after a run of maybe 20km including slow traffic and motorway running around 2500rpm with the occasional kickdown to maybe 3500 rpm:
P1300 = CATALYST DAMAGING MISFIRE MULTIPLE CYLINDERS DRIVE CYCLE C, WHICH HAS OCCURED 7 TIMES
P0304 = CATALYST DAMAGING MISFIRE CYL 4 DRIVE CYCLE C, WHICH HAS OCCURED 7 TIMES
P1000 = CATALYST DAMAGING MISFIRE CYL 7 DRIVE CYCLE C, WHICH HAS OCCURED 7 TIMES
P0302 = CATALYST DAMAGING MISFIRE CYL 2 DRIVE CYCLE C, WHICH HAS OCCURED 5 TIMES
(SIGNAL TOO HIGH, THE FAULT IS CURRENTLY PRESENT, THIS FAULT DOES NOT GIVE MIL LAMP ACTIVATION, THE FAULT HAS BEEN DETERMINED AS PERSISTENTLY PRESENT).
Given that cylinder 2 has now added itself to the initial culprits and the fact that the vehicle was laid up in hot and humid conditions I am inclined to suspect degradation of the plug lead insulation. Would you agree?
I have some on order with plugs from the UK, which is unfortunately closed today for a bank holiday. However I hope to have them in a week or so.
Once again thanks for your input.
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
misfire help MR.T Discovery Series II 7 05-11-2011 07:36 PM
Misfire antelope44 Discovery Series II 1 03-09-2011 03:40 PM
Only one code left - P0306 - persistent #6 misfire - why? krigsmakten Discovery Series II 8 01-09-2011 09:07 PM
Misfire HELP! mrach21061 Discovery Series II 28 12-13-2007 07:38 PM
Misfire mrach21061 Discovery Series II 19 10-15-2007 05:07 AM
You may post new threads
You may post replies
