A pillar removal - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 07-26-2010, 04:10 PM   #1 (permalink)
bmxer06pa's Avatar
Default A pillar removal
i have decided to run my roof light wiring down the A pillar outside the windshield, but i understand it is very difficult to get on and off. i was hoping someone might have some tips to help me out so i dont break the cover.
thanks
doug
2000 Disco II. New head gasket , 3" rte lift, tom woods custom ds ,sd rack. 265 75 16 bfg mt's, Greg Davis rear bumper, Lucky 8 front winch bumper with 10k winch and synthetic line, Qt diff guards, equippe steering and fuel tank skid, sliders and Arb lockers front and rear.
bmxer06pa is offline   Reply With Quote
Old 07-26-2010, 05:18 PM   #2 (permalink)
When you open the door and look at the part of the exterior a-pillar that was concealed with the door closed you will see three plugs. Taka a punch and punch out the center of each of these plugs. That will release that part of the pillar. There are three metal clips that secure plastic studs into the outer side of the pillar. These are a little trickier to release as you have to gently pry the pillar out and forward to release the metal clips and studs. These are what usually break. Easy does it.
Old 07-27-2010, 04:52 AM   #3 (permalink)
xhevi's Avatar
Took a quick look agt my truck this morning... seems like i can tuck the wires underneath the A pillar cover without having to remove it... if u slighty pull on the plastic cover seems like there is enough gap between the windshield and the plastic rubber molding... might require patience and maybe to run the wires one at a time.... will let u guys know how it works out..
xhevi is offline   Reply With Quote
Old 11-28-2012, 10:09 AM   #4 (permalink)
... ... ... well ??? We're not getting any younger around here you know.
2001SE7 is offline   Reply With Quote
Why was my door pillar full of water? Scott1961 Discovery Series II 1 05-18-2010 06:57 AM
pillar of windshield leak RPFdiscoII Discovery Series II 4 03-13-2010 07:28 PM
A-Pillar Gauge Pod Dan Erickson Discovery Series II 12 02-15-2008 09:45 PM
Pillar refinishing 98RRover General Land Rover Discussion 2 10-04-2005 01:16 PM
A Pillar guages Jonesy Range Rover Classic 1 10-08-2004 12:57 PM
SEO by vBSEO 3.3.2
