Old 05-29-2005, 05:03 PM   #1 (permalink)
Default Pitted paint on 2001 Discovery hood
I have a black 2001 Discovery and the hood is covered with little tiny dots that look like white paint specks. Upon looking closer and trying compound to remove we realized they were little "pits" or "holes" in the paint. This is only on the hood. Any ideas what this is? The car is garaged and has never been exposed to any caustic chemicals. The car is not used for off roading so has never had rocks land on the hood. Could this be a defective paint job that is being affected by the heat of the engine?
rcarlier is offline   Reply With Quote
Old 05-29-2005, 05:19 PM   #2 (permalink)
ilovemydisco's Avatar
i have the same problem on my beluga black 1997 disco - pretty sure they are rock chips from highway driving... bug shield will help a little but otherwise nothing much you can do
~Erica~
ilovemydisco is offline   Reply With Quote
Old 05-29-2005, 05:34 PM   #3 (permalink)
Thanks for your reply but they can't be rock chips since the car is driven only in a quiet suburban neighborhood with no rocks or construction sites, and when on the highway has never had any rocks or sand or debris hitting it. Also no bad weather as it lives in sunny California. Also, if rocks were hitting the car there would be damage on other areas of the car. These are tiny tiny little pin prick size pits.
Old 05-29-2005, 05:48 PM   #4 (permalink)
Wheeler
SCSL's Avatar
Can't help you on the why. Haven't heard of heat having this effect on the hood paint. But you can get original touch-up paint from Roversnorth.
www.roversnorth.com
Old 05-29-2005, 06:45 PM   #5 (permalink)
Mod. --- I'm watching you
darkknight1999's Avatar
I would also say its from road dirt/rocks hitting the hood. If it really bothers you, you can get a 3M clear bra installed. Its a 1/16 of an inch of clear rubber protectent. It will protect your paint from chipping for quite a while. Its can be expensive but its sounds like that's what you need.
-John
Some of my favorite quotes:
"what you do in life, echo's in eternity..."
"death smiles at us all... all a man can do is smile back..."
1999 Discovery II SE-7
darkknight1999 is offline   Reply With Quote
Old 06-01-2005, 01:55 PM   #6 (permalink)
Chris Hyde's Avatar
You could always purchase one of my Hood Blackout kits and cover it up.
Chris Hyde is offline   Reply With Quote
