2000 discovery 2 v8
as im sure many of you know, and i know...to replace one plug wire at a time, not so true on the disco 2, my knuckles are all blistered up. heres what i did, i removed all the plug wires all at once. i know the firing order is 1,8,4,3,6,5,7,2. i also have the diagram in my owners manual.
diagram of cylinders
pass side / drivers side from back to front look at engine
8 / 7
6 / 5
4 / 3
2 / 1
from left to right where the plug wires go
2,3,4,7,8,5,6,1
heres my problem, the coil packs are perfect squares, 4 that go up high and 4 that go down low. the diagram in the owners manual shows them going straight across and not 4 on top and 4 on the bottom.
CAN ANYONE TELL ME THE TOP 4 FIRING ORDER (FROM PASSENGER SIDE TO DRIVERS SIDE LOOKING AT THE ENGINE FROM THE FRONT) AND THE BOTTOM 4 (FROM PASSENGER SIDE TO DRIVERS SIDE LOOKING AT THE ENGINE FROM THE FRONT)
i hope i explained the problem i have pretty well, but rt now the truck is sitting out side plz help ASAP!!!
