Old 06-26-2008, 11:44 AM   #1 (permalink)
jmrivera's Avatar
Default Pool of fluind on inside of rear wheel...
Hi all,
I have noticed over the past week that there is a small 'pool" of fluid on the interior if my driver's side rear wheel... I am assuming that this is a leak from the rear end, possibly a seal gone bad...
Anyone have any experience in wheel hub disassembly and/or repair? I am assuming it is pretty straight forward, as long as I am willing to get dirty...
Oh yeah, no indicator lights have popped up, whew, knock on wood...
Thanks,
Jonathan
'03 Disco HSE7 w/ACE and SLS
jmrivera is offline   Reply With Quote
Old 06-26-2008, 02:16 PM   #2 (permalink)
jmrivera's Avatar
Nevermind, even though no one gave a response...
If anyone care, I checked RAVE and it is a simple o-ring that sits on the end of the hub assembly... Now to find the o-ring.....
Old 06-26-2008, 03:26 PM   #3 (permalink)
Ftc4919
roverhouse is offline   Reply With Quote
Old 08-03-2008, 05:55 PM   #4 (permalink)
Stupid > Ignorant
Did you ever get around to fixing this?
I replaced the O ring with a new one and I am still getting leak. I was hoping to get away cheap. I guess I will be changing out the whole hub.
DailyDrivenTJ is offline   Reply With Quote
Old 08-04-2008, 06:26 AM   #5 (permalink)
Need to replace your hub to correct the leak.
Old 08-04-2008, 07:14 AM   #6 (permalink)
brian4d's Avatar
Default ??
I wonder why that is. Oh, I almost forgot it's a Rover. It would make too much sense to just replace a .95 cent o-ring.... Nope, you're going to have to buy a new hub for $350.00. I'm guess the hub wears from stress and might warp?
Brian Morgan
I bitch because I can, I can because I live in America.
2002 Discovery SE (Stock - No ACE, No SLS)
1995 Nissan Pathfinder SE (Sold)
1999 Chevrolet Cavalier (Red Bullet)
brian4d is offline   Reply With Quote
Old 08-04-2008, 10:15 AM   #7 (permalink)
Toowild78's Avatar
I replaced only the o-rings on the both sides of my 03 and that fixed the problems. The o-rings are about 7$ at the dealership.
Toowild78 is offline   Reply With Quote
Old 08-04-2008, 10:30 AM   #8 (permalink)
Stupid > Ignorant
dang... I think I picked up my genuine LR O rings from AB for like a dollar.
Old 08-04-2008, 10:35 AM   #9 (permalink)
Stupid > Ignorant
I changed it out, it is still leaking. My old seal did not have any problem.
When I was pulling everything out, I noticed the leak was not coming between the tube and the hub, oil trail was originated between the axle flange and the hub body, where things rotate.
It is not just the hub wears but the hub itself has seals in it.
I just hope this is the last thing I have to fix for awhile.
Old 08-04-2008, 11:48 AM   #10 (permalink)
brian4d's Avatar
I'll hope with you, maybe if we get enough hopers you'll be good.
Brian Morgan
Old 08-04-2008, 01:19 PM   #11 (permalink)
Toowild78's Avatar
sorry to hear that mine was a bit different, when i took mine apart the hub assembly and bearings were in good shape. the orings were clearly damaged. If you need to replace the hub assembly roverlandparts has them for under $200.00 with the ABS sensor. Good Luck.
Old 08-04-2008, 05:11 PM   #12 (permalink)
jmrivera's Avatar
DAMN! not what I wanted to hear!!!
I have not been able to complete this repair... Hopefully I can get to this reapir soon, before I loose all of my fluid...
I'll post an update when I complete the repair and maybe I'll get lucky...
Jonathan
'03 Discovery HSE7 w/ACE and SLS...
Old 08-04-2008, 05:42 PM   #13 (permalink)
Stupid > Ignorant
I wish I knew of Roverland.com before I pulled the trigger.
I ordered the hub from Atlantic British this morning. It should get here by Wednesday. I will let you know how it turns out.
BTW it is random but the dealer wanted $18 for 4 bolts and nuts for the front Dshaft. WTF.
I thought some American Car dealers were bad, LR dealers are worse.
This Locker or that Locker xd97disco Accessories 368 07-08-2008 09:15 AM
18X9 Wheels on my 2inch lift 95 classic tebelleh1 Range Rover Classic 9 04-23-2008 11:06 AM
Rear Wheel Seals- yeah it's a n00b question- TooSlowMonroe Range Rover Classic 4 01-28-2007 09:08 AM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 10:41 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
