Old 05-13-2008, 07:35 PM   #1 (permalink)
Grid_Lock's Avatar
Default Possible ACE issue on a 99'?
Since I've bought my rover, its ACE has had issues. Mike helped me to lower the sound of the pump, so thats better; but now I've put two and two together, and i'm thinking this is also an ACE related issue.
My Disco II makes a sound at around 15-40 mph on good straight road, and rocks just noticeably when the sound happens.
I would compare the sound to that of when you are driving across a bridge, and your tires hit the metal expansion slots.
Its a very low pitch, a somewhat quiet and hollow sound. it just a "pffft" sound. it happens for no rime or reason, and i only notice it when driving slowly on really flat good pavement.
When the sound happens, the car has a tad bit of a rock to it as well. I would compare the rocking of the vehicle to when you get off the gas, and hit the gas again. that kind of clunk feeling
I'm thinking this might be the ACE because i believe, and i could be wrong, that the sound is coming from the front right.
When i drive, the car handles very well, and the body stays normal to the road, so i don't have any reason to believe it is malfunctioning.
If you have any thoughts or suggestions, please let me know.
Grid_Lock is offline   Reply With Quote
Old 05-13-2008, 09:31 PM   #2 (permalink)
Black 2001 Disco SE7 ACE
Hi,
it doesn't sound like an ACE problem to me. You should check the oil level in your front axle (diff), and look at the front prop shaft. These should be easy to check before you start looking at the ACE.
Keep us posted
Ioan is online now   Reply With Quote
Old 05-14-2008, 06:10 AM   #3 (permalink)
Sent you a PM.
Time is running out for Moab travel management comments jimfoo The Lounge 2 11-13-2007 01:27 PM
Another window issue Disco Truck Discovery Series I 5 03-16-2007 06:41 PM
Discovery I Issue hoberock Discovery Series I 15 02-06-2007 04:48 AM
Got My Issue of Land Rover Lifestyle Magazine WCURoverD90 General Land Rover Discussion 23 01-20-2006 06:14 PM
97 disco tranny issue dirkmc3 Discovery Series I 5 09-23-2005 08:27 AM
