Old 03-01-2006, 06:49 PM   #1 (permalink)
drum655's Avatar
Default power steering
So today i was driving along...and all of a sudden my power steering went out!!! can anyone help me?
2001 Disco II SE w/CDL
~Equipe 4x4 Winch Bumper
~Custom steel rear bumper
~Equipe 4x4 steering skid and radiator skid
~RTE rocksliders
~QT services front and rear diff guards
~2" RTE lift
~265/75 r16 Federal Couragia MTs
~Superwinch X9
~Safety Devices Roof Rack
drum655 is offline   Reply With Quote
Old 03-01-2006, 06:58 PM   #2 (permalink)
any obvius signs sounds leaks ? throwus a bone...
papabeefis is offline   Reply With Quote
Old 03-01-2006, 07:01 PM   #3 (permalink)
drum655's Avatar
nope nothing...one minute it worked...the next it didn't.....no noises, no leaks, no broken belts...no nothing!!!
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 03-01-2006, 07:09 PM   #4 (permalink)
Choqiees's Avatar
did it feel heavy for a moment and normal again ?
if so then it's your steering box set...been there with the P38
2002 Discovery II SE
1999 Range Rover P38 HSE
Old 03-01-2006, 07:11 PM   #5 (permalink)
drum655's Avatar
no it is out and has not come back!!!
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 03-01-2006, 07:23 PM   #6 (permalink)
Super Moderator
Disco's Avatar
It might have got air into it, how, if you have no visible leaks I don't know. Perhaps a good bleed (power steering that is) might solve the problem.
Old 03-01-2006, 10:58 PM   #7 (permalink)
How many miles on the truck, have you ever changed the p/s fluid?
Most likely the gear box has failed, mine di at about 30K and has to be replaced.
Air won't cause what you are describing, so assuming you didn't loose your belt, you better have it towed in to your favorire shop.
