I just got my first land rover 2000 disco series II and will have a lot of questions as I hope to do most of the work myself. The first thing I have run into is a slight leak in the power steering hose. (The repair manual is in the mail) I need to add some power steering fluid however the owners manual suggest texaco. The dealership suggested something I can only get from them and I live 200 miles away. Any suggestions on what to use? Cheers
Hey Mike thanks for the help, just to clarify the valvoline power steering fluid can be used on system with ACE? because a local mechanic said that since I have the ACE system I would have to use the land rover psf. It has 80K and is in need of all the regular 90K work. Over the next couple weeks I plan on trying to get that done. Cheers
Works like a champ.
Do you know how to service the ACE? If you want to do it your self and save money on doing both the steering and ACE, get back to me.
Land rover recomends Texaco Cold Climate PSF 14315 but... You might know that Cheveron bought Texoco and Havoline, I picked up some Havoline PS fluid (Amber in color) the other day, it also had the Texoco symbol on the label. I've had a heck of a time with a moaning noise ONLY when I turn my DIsco to the right when she's warmed up. I also have a slight viberation in the steering wheel around 35 mph then goes away. 3 power steering flushes, 3 quarts of Vavoline Syn, and 2 bottles of lucas later I'm right back where I started. The Val Syn is not amber in color, if memory serves me it's clear yellow. I can say this. I put the Havoline PS fluid in (LR Recommended) and I've not heard the sound in 24 hours, keep your fingers crossed!
Mine leaks like a siv, and and moans only when its first startup, usually cold. Once its warm, not a peep - and it usually doesnt leak (fluid probably expands to much to leak - moan is obviously from air in the system). My pump requires replacement, but the fluid I use is valvoline.
That early moan can be a valve hanging up for a bit and or too heavy a fluid usually caused by adding Lucas or some of the other heavier fluids. It happened to me going into last winter, when using a bottle of Lucas, I removed at least a pint of the fluid/Lucas mix replacing it with Vavoline and it has been fine ever since on those really cold morning starts.
Where can I get Texaco PSF 14315 ? Is there an equivalent, i.e. Mineral oil?
As already mentioned, it is not made any more, you could use Havoline or any other major p/s fluid but don't use mineral oil, it is not intended to be used in our trucks.
