Old 06-26-2008, 02:51 AM   #1 (permalink)
New Yawker in California
RudemanRB's Avatar
Gallery: 1
Default Power window has power but....
No window.
last night my driver side power window went down, but never came up.
I can hear the motor running so I know it's not that.
has anyone encountered this before? is it that the window is off of the track?
or is it some plastic gear that might be broken.
I wanted to ask before I took of the door card.
also is there any simple way to take off the door card?
Help.
Rudy
RudemanRB is offline   Reply With Quote
Old 06-26-2008, 05:48 AM   #2 (permalink)
broken regulator part # cuh102300
roverhouse is offline   Reply With Quote
Old 06-26-2008, 06:15 AM   #3 (permalink)
brian4d's Avatar
Default How hard?
I've taken the door card off my Disco before. How hard is it to replace the regulator? What tools?
brian4d is offline   Reply With Quote
Old 06-26-2008, 12:07 PM   #4 (permalink)
I am not sure what regulator part is mentioned above. When mine stopped working, I found it was a busted slider. Dealer said they did not sell the part and tried to sell me an entire regulator. I took a plastic slider for a 300SD Mercedes window regulator, split it in half, ground one half down slightly, and used it. Worked like a charm. Never had another problem.
tyl604 is offline   Reply With Quote
Old 06-26-2008, 02:29 PM   #5 (permalink)
The Regulator Is The Scissors Unit And A Large Phillps And 8, 10 Mm Sockets . Not To Hard Maybe An Hour Total. The Gear Comes Unwelded From The Mechanism.
Old 06-26-2008, 03:00 PM   #6 (permalink)
I had the same thing happen except that I also heard a loud metal thump. That turned out to be the gear that the motor moves to actuate the regulator. there are three small spot welds that failed. I drilled them out and riveted the gear back in place. The window has been perfect since.
But most likely the others are correct and you will need to replace the regulator
Good Luck
Shawn
Shawnh77 is offline   Reply With Quote
Old 06-27-2008, 09:37 AM   #7 (permalink)
RudemanRB's Avatar
Gallery: 1
Thanks to all,
last night I took of the door card, and was aleast able to get the window to close while I order a regulator. sadly I must wait till pay day next week *sigh*
Rudy
Old 07-02-2008, 09:23 PM   #8 (permalink)
Can someone tell me hw to get the door panel off and get to the regulator ? I have one day before the 4th of July to get the part and window bak up before I go out of town. Any directions, manuals or pictures would help a lot.
Thanks in advance
bcwormley is offline   Reply With Quote
power window electrical issue hermanpj Range Rover Classic 10 02-01-2008 07:48 AM
driver side front window REFERJOHN Discovery Series II 6 10-15-2007 06:31 AM
power window switches pan2sa Range Rover Classic 0 10-09-2006 07:31 AM
broken power window legarrec Freelander / LR2 5 10-07-2006 02:11 PM
Power Window Issue Roving Westward Range Rover Classic 3 09-12-2004 03:10 PM
