Old 10-01-2004, 09:17 PM   #1 (permalink)
Default Premium vs. Regular unleaded
The newer Disco's call for premium unleaded gasoline. Does anyone know if these have a knock sensor? If so, could we use regular gasoline? Anyone currently running sub-90 octane with no probs?
bonemonkey is offline   Reply With Quote
Old 10-01-2004, 09:56 PM   #2 (permalink)
We have a 2000 and it runs fine on 87 as we speak. We put in a tank of 92 ever so often.
mbruneaux is offline   Reply With Quote
Old 10-01-2004, 11:04 PM   #3 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
I have a '95 Disco (which also calls for premium), and it sounded like it was going to die with 87 in it, when I put in 92 it sounded much much healthier.
FelixLockhart is offline   Reply With Quote
Old 10-02-2004, 07:44 AM   #4 (permalink)
Default 99 Disco I
My 99 runs fine on 87.
S Couch is offline   Reply With Quote
Old 10-02-2004, 08:04 AM   #5 (permalink)
They will run on 87 but you will loose gas mileage and power.
It is OK to run 87 if you have to and it will carbon up your engine big time if you continue to use it.
In the long run it will cost you more to run 87.
Mike J.
Old 10-04-2004, 05:57 PM   #6 (permalink)
thanks for the info
Old 10-04-2004, 06:32 PM   #7 (permalink)
I don't own stock but I try to only put Chevron in mine. I've had a couple of really good mechanics as friends and thats what they put in all thier cars. The additive helps keep things clean. I've used the Unleaded (midrange) and get fine results but switch on occasion to the high grade. I burn a lot of interstate miles I don't know how that plan will work with constant stop and go traffic.
Helopilot is offline   Reply With Quote
Old 10-06-2004, 07:19 PM   #8 (permalink)
i have heard the same thing about chevron.
taylorbob1 is offline   Reply With Quote
Old 10-15-2004, 07:31 PM   #9 (permalink)
well no wonder i get crappy gas milage with 87 =c)
i'll try using better...but i've never had any knocking issues or anything of the sort using 87.
1997 Disco SE -Forest Green
K&N Air Induction System
RoverTek Performance Computer
BORLA Exhaust System
OME H/D Shocks
31'' Good Year Wrangler MT Tires
RoverTym 2'' Lift Springs
Kenwood MP3 Player
Kenwood 800W Amp
2 10' JL AUDIO Sub's In Custom Box
In Car DVD System W/ 3 6.5'' Monitors
1990 Nissan Twin Turbo 300ZX 700HP
1992 Nissan Non Turbo 300ZX 300HP
Toddicus is offline   Reply With Quote
Old 10-15-2004, 08:14 PM   #10 (permalink)
beer drinking member
dent's Avatar
over the long run what you save from running sub 90's will cost more in a valve/ head job. these land rovers are known for sticky valves so why compound the problem but adding to it?
take care
sam
dent is offline   Reply With Quote
Old 10-16-2004, 09:16 AM   #11 (permalink)
Dent,
I couldn't have said it any better. As the old saying goes," Pay me now or pay me later", only problem is that you will pay alot more later then what you, THINK, you are saving now. If you are the type that likes to get out off road you will also loose in perfromance.
Mike J.
