For those of you who have the Dave Lucas QD, what tool did you use to remove the lower bolt? That T-40 Torx Bit is not doing the trick......My truck is very RUSTY from living in NY. Any advice??? THANKS!
2006 Range Rover Sport HSE Rimini Red 2001 D2 CDL ![]() 1998 D1 ('Henry' Sold 05/05 Bought Back 01/06 Retired) 1988 RRC SWB ('Silver Bullet' Retired 05/98) |
Otherwise known as STEVE
The T40 doesn't fit or you just can't get em to turn?
#3 (permalink) | |
Hi Steve! No it fits but......I guess I am not strong enough to hold the bit while turning the box wrench?? LOL! Is there another tool??
Bang the bit in with a hammer and then take it out.
I got an impact driver set that does the trick. if you get one for that go for it. It uses the hammer as a means to break the rust and get it out. |
#5 (permalink) | |
Awesome! Will do thanks! It is rusted on there (LOVE NY Weather) which is why it is a pain. So then I still use the box wrench? I was using a 18mm socket but all it does it turn, so without the bit the 18mm is useless. Thanks! Beezel, we stopped by your dealership by the airport in Albany back in FEB 2006, not sure if you were there or not though?
Soak it in PB Blaster several times a day for a couple days.
#9 (permalink) | |
OK! Thanks, I had some issues but I was able to get the driver side...THANK GOODNESS! But the Passenger Side is a Pain in the ARSE!!! I just ordered Dave's Sliders so I am really excited about them arriving too! Any advice Mr. NorthCal ? ![]()
#10 (permalink) |
![]() Join Date: May 2005
personally...i would just put a small screwdriver or something through the hole in the pin where the pin goes that holds the disconnect on. this will keep it from spinning and then you can use a box wrench or socket to get the nut off....i hope this help!
Moderator of the East Coast and Discovery 2 sections! 2001 Disco II SE w/CDL ~Equipe 4x4 Winch Bumper ~Custom steel rear bumper ~Equipe 4x4 steering skid and radiator skid ~RTE rocksliders ~QT services front and rear diff guards ~2" RTE lift ~265/75 r16 Federal Couragia MTs ~Superwinch X9 ~Safety Devices Roof Rack |
#11 (permalink) | |
1) I’d spend some time prepping your sills once you take the plastic crap off. Dave says cleaning/waxing is sufficient, but I have a feeling the sills will rust after you keep the sliders on for a while. This would be especially true in your wet weather conditions. I didn’t prep mine in any special way, but in the next month or so I’ll be taking the sliders off and treating the areas around the holes with something rustproof. 2) DO NOT OVER TIGHTEN the nyloc nuts! Here’s the deal, the sliders are designed in such a way that they’ll “clamp” around the seal, so naturally you have to “squeeze” them together when you put the bolts on. Problem is, the sills are so damn fragile that if you are not paying attention, it’s very easy to “squeeze” them too much and actually deform the sill ! End result will yield a bulging sill inside your truck, right where your plastic retainer bolts on to secure your carpet to the floor. The nuts screw on so easy that even with a small hand wrench it’s hard to notice when you are starting to over tighten. Point is, go slow and keep checking to see if you got the slider “clamping” around the sill with 90 angles. Otherwise you’ll be banging the sill back in shape with a hammer Hope this helps and good move on Slickrocks!!! ![]() p.s. oh crap, I just read the "new" instructions on Dave's site... says about the same thing that I've mentioned above!!! AAAHHH!!! He didn't have those instructions when I got mine!!! ![]() |
#12 (permalink) |
Great Advice! Ok well here is the finished product! Many hours later! LOL!
#14 (permalink) |
I quickly disconnected my sway bars from my chassis and now they're laying on the floor at work.
Actually the rear sway bar was quickly disconnected at Devil's Ditch, to much articulation. Truthfully with HD rte springs I don't miss them.
It just doesn't matter. |
#15 (permalink) |
It sort of was a pain in the a** to be honest. Have you added the grease as mentioned in the directions, Alex?
Now on the rear sway bar Walt, can I just pull it when off-roading? And then replace once I am back on the trail again? Thanks ![]()
