Old 12-19-2006, 07:03 PM   #1 (permalink)
Default Rattling/Grinding Noise in 2004 Disco G4...
I took the G4 in for the 37500 service and had them check out an M&S light issue. They did the service and said the M&S was due to a faulty battery, so they replaced the battery.
After leaving the dealer, I drove the Disco about 100 miles, stopping at several places on the way home. After arriving home, I parked in the driveway for about 10 minutes to unload a few things. I went back out to pull the truck into the garage, and when I started it up and shifted into reverse, a rattling/grinding noise started coming from what sounded like the lower engine area. I immediately jumped out and popped the hood to see where the noise was coming from but before I could get the hood open, the noise stopped.
I've been racking my brain to think about what it could have been, and the only thing I can think of is the tech at the dealer dropped an oil container cap into the engine, but that sounds ridiculous.
What do you guys think this could be?
Bernard Mann
2004 Disco G4 (Sold to Josh Lester)
2005 Mercedes C230
2003 Disco S (Sold)
bernardmann is offline   Reply With Quote
Old 12-19-2006, 07:11 PM   #2 (permalink)
Its worth a shot but do you have any oil in the vehicle. your not leaking at all are you?
Sorry I have to ask. It can and does happen to the best of us.
Anyway, if all is good. dont bother unless it comes back and alot. Otherwise the techs aint chasing down a one time thing. Especially if it aint doing it.
Old 12-19-2006, 07:16 PM   #3 (permalink)
Yep, checked oil and other fluids, and everything is good-to-go.
Bernard Mann
2005 Mercedes C230
2003 Disco S (Sold)
Old 12-19-2006, 07:47 PM   #4 (permalink)
Otherwise known as STEVE
Didja find a socket in the driveway that isn't yours?
Heat shields can make a huge scary noise if they rattle- Or did it really sound like something IN the engine?
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 12-19-2006, 08:00 PM   #5 (permalink)
Sorry I was participating in the new skyguy thread on Dweb - what a maroon that idiot is...
No, I thought the same thing and checked the driveway, but nothing fell out. It sounded like the engine, or maybe T-case was grinding something up...
Bernard Mann
2005 Mercedes C230
2003 Disco S (Sold)
Old 12-19-2006, 10:44 PM   #6 (permalink)
Dude- I've got no idea- Did it stop when you put it back in Park or only when it was in reverse? Did it seem related to the RPM? It could have just been a heat shield or something. Any chance you bumped the hi-lo lever and it wasn't completely in hi?
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
Old 12-20-2006, 05:30 AM   #7 (permalink)
I know, this is perplexing. It sounded like the engine or T-case was grinding something up. It started when I put it in reverse, then stopped a little bit after I put it in park and jumped out to pop the hood. It wasn't related to RPM's. I know it wasn't a heat shield - I know that sound. I didn't bump the HI/LOW lever, either. I'm going out to look at things in the daylight, maybe it'll be more evident this morning.
Bernard Mann
2005 Mercedes C230
2003 Disco S (Sold)
Old 12-20-2006, 07:11 AM   #8 (permalink)
Were you moving, after you put the tranny into reverse and then it started making the noise? Try starting the truck, while not moving put the tranny into reverse or drive, any noise, now let the truck move while in either gear, does it now make the noise?
I am wondering if you are having a diff failure.
Old 12-20-2006, 03:53 PM   #9 (permalink)
I got in started it up and put it in reverse and started backing up. That's when the noise started. I put it in park and as I was jumping out to pull the hood release, the noise stopped. I haven't been able to replicate the noise since last night, either. I've been driving all day. Just weird.
I'm thinking it was the transmission. I've been having vibration issues between 2nd and 3rd gear. When I took it into the dealer, they said they it wasn't acting up so they didn't do anything to it. I'm probably going to take it to LR Cape Fear after the holidays to get them to give it a look.
Bernard Mann
2005 Mercedes C230
2003 Disco S (Sold)
Old 12-20-2006, 04:09 PM   #10 (permalink)
If it were the tranny and it was causeing that sort of noise and vibration, it should have set the trannt mode lights off.
If it happens again, I would get it into someone for a better look.
Good luck,
Old 12-20-2006, 04:12 PM   #11 (permalink)
Good luck,
Thanks Mike. I'm just going to keep driving it and not worry about it until it happens again.
Bernard Mann
2005 Mercedes C230
2003 Disco S (Sold)
Old 02-11-2007, 09:40 PM   #12 (permalink)
If it was a manual I'd day it was a failing flywheel. That happened to me and symptoms were vert similar. The dual mass flywheel and begun to fall apart and made grinding noises from time to time, interspersed with long periods without any symptoms at all. As far as I know, the auto does not have such a flywheel
alex is offline   Reply With Quote
