Old 05-08-2008, 01:19 AM   #1 (permalink)
Question RE: checking tramission fluid level in disco 04
my tranny's acting up and would like to check the fluid level but cant seem to fing any stick in the engine.
anyone got any ideas where to look and how i could check it
olumide is offline   Reply With Quote
Old 05-08-2008, 03:17 AM   #2 (permalink)
Ian Matthews
p76rangie's Avatar
It is checked via the filler hole on the side.
Old 05-08-2008, 01:31 PM   #3 (permalink)
Crawl under the truck, find the filler hole in the siide of the pan, loosen the plug, then go start the engine, shift from reverse to drive 2 time, put it back in park with the engine still running know go pull the fill plug. If fluid comes out, you are OK, if not, you need to add.
Replacing ACE Fluid in Disco II discoma Discovery Series II 8 04-08-2008 02:57 PM
01 disco II tranny fluid kimmiekerry Discovery Series II 11 04-04-2008 07:24 PM
wheel cylinder rebuilding theclay Series Land Rovers 23 05-21-2007 04:45 PM
Brake fluid level warning Vinosdad Range Rover P38, Mk III and Range Rover Sport 3 03-28-2006 03:28 PM
change radiator fluid series 2 disco Quinny General Land Rover Discussion 0 03-11-2005 10:45 PM
