Old 07-16-2008, 02:38 PM   #1 (permalink)
Disco Dave
djblai2's Avatar
Default Rear Differential??
Hey Guys,
I think my rear differential is going out. I keep hearing popping noises while I slow down. I don't know if the person who owned the Disco 01 before me did a lot of off-roading in water or what, because when I changed the fluid it was nasty and milky colored. Anyways, I noticed one of the teeth was missing. I figured that is where the popping noise is coming from, am I right? How much does it cost to replace it or is this something I could do? Thanks...
David
David
djblai2 is offline   Reply With Quote
Old 07-16-2008, 03:06 PM   #2 (permalink)
Rebuilding Rover
ArmyRover's Avatar
The third member is easy to replace. 3-4 hour job. What you want to do is pick up the complete third member.
Then it's just a matter of:
Jacking up the truck
taking off the rear tires
unbolt the driveshaft
5 bolts per axle, slide the axles out of the diff.
drain diff
unbolt the diff and work it out of the axle housing
swap replacement third member in.
reassemble
contact Paul Grant here on the forum using private message, he should have something laying around knowing him. Paul has a lot of rover parts on hand at great prices and great service.
If he doesn't have one let me know and I'll point you to some other people to try.
http://www.wheelinrovers.com/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 07-16-2008, 03:26 PM   #3 (permalink)
Ian Matthews
p76rangie's Avatar
It sounds like you only need to change the centre. It is probably only 1 to 2 hours. It is something you can do yourself. You can pick up a second had centre relatively cheap.
p76rangie is online now   Reply With Quote
Old 07-16-2008, 03:34 PM   #4 (permalink)
Used 3rd. members can be bought pretty cheap, Differentials - Rear Differentials
Sometimes lower when purchased direct from someone who is parting out a truck.
Old 07-16-2008, 09:17 PM   #5 (permalink)
Disco Dave
djblai2's Avatar
Thanks for the great info. I will see what I can do and let you know how it went.
David
Heavy Duty Package Rear Locking Differential gtiturbolr3 Discovery 3 / LR3 7 04-16-2008 06:58 PM
88 Range Rover rear differential ROVERMAN Land Rover Parts and Accessories 0 11-21-2006 10:57 AM
Scorpion Racing Rear Bumper Install w/pics. beavis4g63t Discovery Series I 10 10-17-2006 02:38 PM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 10:41 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
