Rear Differential?? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 07-16-2008, 12:38 PM Thread Starter
Disco Dave
djblai2's Avatar
Quoted: 0 Post(s)
Rear Differential??
Hey Guys,
I think my rear differential is going out. I keep hearing popping noises while I slow down. I don't know if the person who owned the Disco 01 before me did a lot of off-roading in water or what, because when I changed the fluid it was nasty and milky colored. Anyways, I noticed one of the teeth was missing. I figured that is where the popping noise is coming from, am I right? How much does it cost to replace it or is this something I could do? Thanks...
David
David
djblai2 is offline
post #2 of 5 (permalink) Old 07-16-2008, 01:06 PM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 37 Post(s)
The third member is easy to replace. 3-4 hour job. What you want to do is pick up the complete third member.
Then it's just a matter of:
Jacking up the truck
taking off the rear tires
unbolt the driveshaft
5 bolts per axle, slide the axles out of the diff.
drain diff
unbolt the diff and work it out of the axle housing
swap replacement third member in.
reassemble
contact Paul Grant here on the forum using private message, he should have something laying around knowing him. Paul has a lot of rover parts on hand at great prices and great service.
If he doesn't have one let me know and I'll point you to some other people to try.
1972 MGB
2007 Chawton White LR3
Trident Green, 1983 110
Need new parts, genuine Land Rover, aftermarket and off road upgrades, Support the Vendor that supports the Land Rover Community and Forum
716-898-8153
Have a DII you need a drive shaft click here
Want a
best read this first
Need used parts?
ArmyRover is offline
post #3 of 5 (permalink) Old 07-16-2008, 01:26 PM
Ian Matthews
p76rangie's Avatar
Quoted: 151 Post(s)
It sounds like you only need to change the centre. It is probably only 1 to 2 hours. It is something you can do yourself. You can pick up a second had centre relatively cheap.
p76rangie is offline
post #4 of 5 (permalink) Old 07-16-2008, 01:34 PM
Administrator
Quoted: 5 Post(s)
Used 3rd. members can be bought pretty cheap, Differentials - Rear Differentials
Sometimes lower when purchased direct from someone who is parting out a truck.
Disco Mike is offline
post #5 of 5 (permalink) Old 07-16-2008, 07:17 PM Thread Starter
Disco Dave
djblai2's Avatar
Quoted: 0 Post(s)
Thanks for the great info. I will see what I can do and let you know how it went.
David
djblai2 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 22 11-10-2009 04:47 PM
Heavy Duty Package Rear Locking Differential gtiturbolr3 Discovery 3 / LR3 7 04-16-2008 04:58 PM
88 Range Rover rear differential ROVERMAN Land Rover Parts and Accessories 0 11-21-2006 08:57 AM
Scorpion Racing Rear Bumper Install w/pics. beavis4g63t Discovery Series I 10 10-17-2006 12:38 PM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 08:41 PM
You may post new threads
You may post replies
