» Featured Product
» Sponsors
» Sponsors
LandRoversOnly.com is the premier Landrover forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 05-30-2007, 10:52 AM   #1 (permalink)
Default Rear Door dragging
the rear door seems to be a little sluggish. And it also seems to be sitting a little lower on the driver side then the passanger. How do you pick it up to make it level?
scottagnew101 is offline   Reply With Quote
Old 05-30-2007, 10:55 AM   #2 (permalink)
what "rear door" are you talking about?
the big swinging one in the back, or a passenger side rear door?
2003 Land Rover SE7
- Stock Hardon Karmon speakers
- Stock Navigation System
- Cold Weather Package
- SLS
- ACE
johnnybob06 is offline   Reply With Quote
Old 05-30-2007, 11:10 AM   #3 (permalink)
Default Having the same issue with the BACK door.
The back door has been a bit sluggish for a while, but recently has begun to scrape the top of the bumper. and damaged the bottom of the door around the catch arm. I have tried to re-align the very heavy door and have not been able to get a better fit, and I am starting to debate replacing the hinges. Anyone dealt with this before?
discofu is offline   Reply With Quote
Old 05-30-2007, 11:26 AM   #4 (permalink)
well it sounds like that is were mine is headed.
And yes, sorry its the one in the rear with the tire
anyone know why this happens, i have 31" tires... i know they are heavier but it shouldnt be this bad.
Old 05-30-2007, 11:52 AM   #5 (permalink)
Product of Cvcimia
slangel's Avatar
Yeah I have a 2000 DII and mine started out sluggish and I regularly lubricate it then one day it would not shut. One hinge just bent a little. I needed to do something about as it is also my DD. I took off the hinge, put it in a vice, used a bar and bent it back. put it back on and haven't had trouble since.
I tried to see things from your point of view, but I couldn't get my head that far up my ass.
I think Cvc's goal is to make me vomit daily with his disgusting avatars.
slangel is offline   Reply With Quote
Old 05-30-2007, 12:09 PM   #6 (permalink)
well after looking at the door carefully. My latch that is on the car was really low, it was just bearly missed hitting the latch on the actual door.
A quick fix for it "grabbing and being rough" is to pack some grease on the arm in the lower passanger conrner on those small divits where it can "rest". this just made mine much eaiser to move.... dunno how long it will last
Old 06-08-2007, 09:47 AM   #7 (permalink)
It shouldn't be that hard to get it adjusted. After an F150 decided to play bumper cars with me I had to get mine adjusted from the body shop who did the repairs. I don't think there was really much to it, even if your hinge is bad.
With door open grab it from the bottom on the inside and lift up on it a few times. There shouldn't be any play at all in the hinges. If there just pick up a new hinge- otherwise you're going to scratch all the paint off the bottom lip of the door and could stress that arm that hooks into the door to keep open.......you know that thing that hooks to bottom of it, whatever its called.
stb616 is offline   Reply With Quote
Old 06-09-2007, 11:53 AM   #8 (permalink)
Thanks for the information. The first thing i did was pick up on the end of the door to see if anythingw as loose. to my surprise it wasnt . And there is no rust what so ever on the hinges. Thanks for the help
Old 06-11-2007, 05:50 AM   #9 (permalink)
Just a thought- your bumber is pushed up at all is it?
SEO by vBSEO 3.3.2
