Old 04-24-2008, 09:28 AM   #1 (permalink)
MikeChiro01's Avatar
Default Rear Pinion Centralising Pin
Ok so after two broken bolts and a headache here I am.
I've been trying to remove the centralising pin so I can replace a leaking rear pinion oil seal.
I built a device out of a harmonic balancer remover and some nuts to help remove the centralising pin.
I got it about 2mm out and it stopped moving.
I've tried heating the pinion with a propane torch, used penetrating oil, looked online and in the forum and the only thing i can find is someone suggested using a slide hammer to get it out.
Has anyone successfully removed this without taking it to a shop?
MikeChiro01 is offline   Reply With Quote
Old 04-27-2008, 07:55 AM   #2 (permalink)
wow, you know it only pays around .8 to replace the seal. we have two devices for the job. First after removing the driveshaft we have a device that goes in the slot of the flange and you slowly turn it out. the next one after installing the seal, holds the flange while you retorque the bolt to the proper specs.
you do know you probably killed the seal and the bearings inside the pinion and most likely the diff right.
wow, you really cut your nose off on that one.
Scorpion Racing Rear Bumper Install w/pics. beavis4g63t Discovery Series I 10 10-17-2006 02:38 PM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 10:41 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
Transfer Case clunk/slack/wear, rear diff pinion wobble Black Magic Discovery Series I 3 07-22-2005 09:31 PM
Rear diff pinion removal clank Discovery Series II 4 10-05-2004 08:05 AM
