Replacing Radiator - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 11-17-2009, 01:45 PM   #1 (permalink)
Default Replacing Radiator
I am replacing a radiator on a 2000 Land Rover Discovery Series II with secondary air.
Is there something at the bottom of the Radiator that needs to be removed? Are there any instructions with photos?
I have all of the hoses removed and the upper brackets, removed (that were bolted behind the horns).
Any help would be greatly appreciated.
larrylynnjr is offline   Reply With Quote
Old 11-17-2009, 02:00 PM   #2 (permalink)
Burncycle's Avatar
Sent you an email.
Burncycle is offline   Reply With Quote
Old 11-17-2009, 02:10 PM   #3 (permalink)
Administrator
Download a free copy of a Rave CD, it will walk you thru what needs to be done.
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 11-17-2009, 02:47 PM   #4 (permalink)
DiscoDream2's Avatar
Cus I'm bored...
Right click the images and save to your desktop, insert into a word document and print to take outside. You prolly can skip down to step 10,11,12??
Don't spill tha S*** all over it, can kill dogs.......
DiscoDream2 is offline   Reply With Quote
Old 07-21-2010, 06:27 AM   #5 (permalink)
Default Radiator replacment
Last night, I began to remove the radiator, I loosened all th hoses, removed the upper brackets, and just seems like it should slide out of the top. Are there more brackets screws/bolts elsewhere to remove? I read somewhere that you need to take out the grill, fan, etc.? Any help would be greatly appreciated.
tadams79 is offline   Reply With Quote
Old 07-21-2010, 06:44 AM   #6 (permalink)
land rover service factory manual RAVE download
Download it, detailed instructions are in there.
Bosbefok is offline   Reply With Quote
Old 01-13-2013, 01:52 PM   #7 (permalink)
Default Replacing 2001 landrover discovery radiator
Remove battery and battery box - 6 bolts, remove air filter box - no bolts, just pull up after unbolting 2 plastic bolts from snorkel....then you can access all the hardware that you need to remove the radiator...you don't need to remove the fan or fan shroud assembly just slide the shroud assembly back...disconnect the 3 coolant lines that are connected to the radiator...do not disconnect the transmission or power steering cooling radiators...not necessary...you can remove the radiator without disconnecting the transmission or power steering coolers.just slide the radiator out...and replace new one..do not remove the front grill either, that is a waste of time...
I just did this job today...very easy.
gregthorum is offline   Reply With Quote
Old 01-14-2013, 07:31 AM   #8 (permalink)
Administrator
And or read the 2 pages in the Rave for step by step instructions.
Also replace the t/stat, coolant cap and consider switching to green coolant.
Need Parts?
Replacing radiator Burncycle Discovery Series II 10 10-30-2009 11:02 PM
Leaky radiator scooby Discovery Series I 1 09-18-2009 08:42 AM
Radiator Problems ichibanCA Range Rover P38, Mk III and Range Rover Sport 0 04-27-2009 06:04 AM
Got the Radiator...now the replacing begins... ugeauxigo Discovery Series II 3 01-14-2009 12:32 PM
replacing radiator myself chrisusvi Discovery Series I 3 04-28-2007 08:23 AM
SEO by vBSEO 3.3.2
