I was just wondering if anyone has expierenced this. At speeds of 75-80 (hwy) there is a vibration/resonance that you can hear and feel. If you speed up just slightly or slow down just slightly it will go away. It has a brand new front drive shaft. It also has the nitto terra grapler tires on it. I have only had the vehicle a few months and last weekend was the first time at those speeds on the hwy.
thanks ![]() |
Super Moderator
Mine does the same thing. They say it is normal.. They being the dealer. You may want to check the fluid level in your transfer case. It might also help to swap the fluid for a good synthetic. It's gear whine that you hear.
Land Rover-less. -------------------------------- 2006 Infiniti QX56 - Loaded 2002 Discovery II SE - SOLD! 1999 Audi A6 Avant Quattro Tiptronic - Slammed on RS4 18's 1996 Mariah Talari w/350 Mercruiser and Ron Hill Marine Go-fast parts.(Presently in Dry Storage) |
I disagree with the above post. If you have a vibration you can feel and hear, the problem most likely is the rear driveshaft rubber flex coupling. The flex coupling substitutes for a U-joint in the rear and tends to wear out. According to DAP, if the coupling has any cracks in it at all it is junk, and can cause even severe vibration as the condition worsens. Mine has this problem. Below a certain speed (like 60 mph-65 mph), there is no vibration. Above that speed, no vibration until you get off the gas. Then, the faster the speed when you let off, the more noticeable the vibration. However, if you get on the gas, the problem goes away. The part is like $60-80; install it yourself.
Current: 2005 Land Rover LR3 V8 SE w/ factory winch 1992 Land Rover Range Rover County Also current: 1995 Mercedes-Benz E320 Wagon 2002 Volkswagen Eurovan GLS 1996 Ford Explorer LTD 2WD 1982 Volvo 240 GL Diesel Previous Rovers: 2000 Land Rover Discovery II SD 1995 Range Rover 4.0SE |
#5 (permalink) | |
Easy job to change out, I think there are only six bolts to remove. Mike |
