Hi Guys.
First I want to thank Joe for diagnosing my 3 amigos problem for me while I was there picking up the skinny roof rails.
Per his really nice scanner, Joe determined that I have a sensor problem on the right rear wheel.
read the RAV, it said to replace the entire hub, obviously don't need to do that (yet).
Found 2 different types of sensors.
Basically, the same sensor, but one has a very long cable and an unterminated pigtail that presumably one has to route all the way up to the ECU/SLABS.
The other type has a much short cable with a cylinder-style connector. BTW, this is the same connector/sensor they show for a new hub assembly.
Can anyone shed some light on which one I should use? Obviously, the short one with the connector eliminates the need to route 10+ feet cabling thru the chassis, but on Atlantic British their front sensor replacement video they say that it is best to route the sensor all the way back to the ECU/SLABS in order to avoid any problems with the intermediate connector.
Any thoughts, input, advice, experience, etc. would be greatly appreciated.
