Old 07-15-2008, 11:31 AM   #1 (permalink)
Smile Rotoflex to the rescue
I signed on as SoMiss last week and asked about vibration at high speeds on a 99 DII with 111K miles...I checked the u-joints and found that there were grease fittings (apparently were replaced). I pumped the grease to all five fittings and replaced the rotoflex...vibration is gone!!!
I do have one question regarding the rotoflex replacement. How do you remove the bushing inside the rear drive shaft?
P.S. SoMiss is where I graduated from college, but looked a little feminine on thread...changed names...anyway, Thanks DiscoMike, Brooksa and Brian for the recommendations.
IsoDisco is offline   Reply With Quote
Old 07-15-2008, 01:42 PM   #2 (permalink)
brian4d's Avatar
Did you get your rotoflex from AB?
Brian Morgan
I bitch because I can, I can because I live in America.
2002 Discovery SE (Stock - No ACE, No SLS)
1995 Nissan Pathfinder SE (Sold)
1999 Chevrolet Cavalier (Red Bullet)
brian4d is online now   Reply With Quote
Old 07-15-2008, 01:53 PM   #3 (permalink)
LR Dealership
Old 07-15-2008, 02:02 PM   #4 (permalink)
brian4d's Avatar
do you mind me asking what you gave?
Brian Morgan
Old 07-15-2008, 02:05 PM   #5 (permalink)
$120.00
Old 07-15-2008, 02:05 PM   #6 (permalink)
jmrivera's Avatar
My dealer wanted $120 for it while roverconnection dot com wants $70... I found another source that wants about the same...
'03 Discovery HSE7 w/ACE and SLS...
jmrivera is offline   Reply With Quote
Old 07-15-2008, 02:07 PM   #7 (permalink)
brian4d's Avatar
Hard to replace, or just throw a wrench a few times?
Brian Morgan
Old 07-15-2008, 02:12 PM   #8 (permalink)
Six bolts...19mm ratchet and open end wrench...should have only taken 10minutes, but I tried to wrestle the bushing out with a pair of vice grips...wouldn't budge, so I did not replace it. Make that 20 minutes.
Old 10-01-2008, 12:08 PM   #9 (permalink)
Do you mind if I ask what the rotoflex does and if it can help me? I've got a 2002 Disco II, and RTE 3" lift and 265's. I get recurring blown seal at the connection of the driveshaft to rear diff, and sometimes the front driveshaft to t-case.
Riflman is offline   Reply With Quote
Old 10-01-2008, 12:36 PM   #10 (permalink)
rmuller's Avatar
Rotoflex is the rubber coupling on the diff side of the rear driveshaft ... it is used to make the ride more comfortable and absorb vibrations.. problem is, when you lift the truck, the angle of it is now making the rotoflex wear out faster.. a lot of people replace it for a double cardan driveshaft with ujoints to eliminate the vibrations & rotoflex..
as for your seal blowing out.. is it the pinion seal on the rear differential? is the surface clean, and the breather line unclogged?
Old 10-01-2008, 12:51 PM   #11 (permalink)
I think it is in fact the pinion seal according to the shop. How do I tell? I don't think I have a rubber boot on the rear of the driveshaft. I think I have greasable u-joints but I will check.
Old 10-01-2008, 05:49 PM   #12 (permalink)
I have the rotoflex. The oil is coming from inside the diff and spraying out. It's collected on the flange. I guess that means the surface isn't clean, but how do I tell if the breather hose is unclogged? The rotoflex looks okay as far as I can tell and there does not seem to be a lot of play in the drive shaft. I called Bill but he was not available. Someone else mentioned a longer driveshaft? Will going to 285's change anything or is all of this because of the lift??
Old 10-01-2008, 05:53 PM   #13 (permalink)
Checked the truck and some pics and it's definitely the pinion seal. How often do these things blow out? My diffs were just rebuilt two years ago.
Old 10-01-2008, 06:58 PM   #14 (permalink)
the seals are crap to start with but with enough rust it can cause issues. you might want to put a new one one with a little aviation sealant and let the thing sit for a bit before driving it.
that might work a bit better.
I was on the road once and saw the leftover rear driveshaft after the lady was on a long trip from cali and the rotoflex failed and the shot the driveshaft like a rear missile.
F/S Rotoflex Conversion Parts Paul Grant Land Rover Parts and Accessories 2 09-21-2007 05:52 PM
Rotoflex wimp Discovery Series II 10 02-13-2007 07:47 PM
rotoflex bama Discovery Series II 4 07-29-2006 09:24 AM
rotoflex? drum655 Discovery Series II 2 03-24-2006 09:25 AM
Rotoflex discorover Discovery Series I 3 04-17-2005 07:41 AM
