Old 07-30-2008, 09:54 PM   #1 (permalink)
Default RR vs Disco II
I am searching for the best 4x4 vehicle for an extensive road trip through Central America. The decision of which vehicle to use is still up in the air. While I know Land Rovers are all extremely capable, the choice comes down to a 2000 or older Range Rover or a Disco (I or II).
Which in your opinions would be most reliable(if i can use that word to describe a LR), and most capable on the roads and terrain of Central America.
In addition to the vehicle I would need to do some work to get it ready for the trip such as roof rack, lights, etc.
Any suggestions, comments are appreciated.
Thanks
dawozman1 is offline   Reply With Quote
Old 07-30-2008, 10:36 PM   #2 (permalink)
Black 2001 Disco SE7 ACE
I suggest you go with a Discovery 1999-2000 Discovery II, with no ACE (active cornering enhancement; basically a stability system) and no SLS (self leveling suspension; an air spring system for the rear suspension).
These 2 systems are amazing, but on a Disco from those years, they can break any time and it will become a huge problem in South America to fix them (especially out of towns).
The Range Rovers come with the air suspension system, and unless a coil spring conversion has already been made, it is too risky to drive it south.
Other than that, both cars have about the same off road capability with maybe the Disco being a little bit better off road, but by a margin that is hard to tell.
As for off road accessories, you can find them for both models.
Best of luck
Ioan
Ioan is offline   Reply With Quote
Old 07-31-2008, 07:45 AM   #3 (permalink)
Ditto!!!
You will have a more capable truck with a slightly modified D2 with a CDL t/case, lift and good tires for less money the a RR.
Should I buy a 97Disco or a Disco II? keroppi Discovery Series I 7 07-24-2008 09:47 PM
95 Disco. Rear windows won't roll up. + starting issues. wRek Discovery Series I 20 07-11-2008 05:04 PM
My trail-ready Disco I for your stock Disco II chelo Land Rover Vehicles 0 11-18-2007 10:55 PM
Pre-95 Disco Newbie needs more advice pfkb72 Discovery Series I 18 09-12-2005 10:49 AM
Help empty my garage! Ton's of parts.. RedRhinoProducts Land Rover Parts and Accessories 9 05-11-2005 02:25 PM
