alright, '99 d2 59k. lately, i start up the truck and around the passenger side, under the vehicle or somewhere; there is a sound of some liquid not really sloshing around but more just running or dripping into something, hard to explain. this is after i initially take off. not after ive been driving around for a while. just when i first take off. uh where should i look? thanks.
It is most likely you're air conditioning drain plugs are clogged up.. crawl under the car (wait for it to be sitting overnight/few hours so its not hot).. on either side of your transmission tunnel there are little rubber drain plugs.. you can either stick a screw driver in them, or just squeeze them to clean them up.. be prepared to get soaked with a lot of black water though.. the passenger one is right about where the cross-member meets the driveshaft (if i remember correctly), so start there, easier to find.. (use a flashlight)..
