Is it safe to mix transmission fluid? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 12 (permalink) Old 02-05-2010, 02:55 PM Thread Starter
WLADiscoII99's Avatar
Quoted: 0 Post(s)
Is it safe to add Mobile 1 synthetic ATF to mix with Castrol or Dextron?
WLADiscoII99 is offline
post #2 of 12 (permalink) Old 02-05-2010, 03:01 PM
Quoted: 0 Post(s)
Are you mixing syn with syn?
1969 LR 109
1970 LR 109 Wagon
1974 MGB
2004 Disco II
vansdonk is offline
post #3 of 12 (permalink) Old 02-05-2010, 04:40 PM
lipadj46's Avatar
Quoted: 0 Post(s)
Yes its fine if you are doing a drain and fill. I would at least do 2 drains and fills though to try to get as much as the old stuff as possible.
2002 DII 114,000 miles
lipadj46 is offline
post #4 of 12 (permalink) Old 02-06-2010, 06:01 AM
Administrator
Quoted: 5 Post(s)
Yes, it would be OK but why waste all that money adding a quart or two of Mobil 1 to so many quarts of dirty old Dextron.
What exactly are you trying to do, add/top off your tranny or a drain and refill?
What condition is your current fluid in, red, or burned and brown?
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #5 of 12 (permalink) Old 02-06-2010, 07:25 AM
Quoted: 0 Post(s)
Use Royal Purple, been using it forever without issues.
1969 LR 109
1970 LR 109 Wagon
1974 MGB
2004 Disco II
vansdonk is offline
post #6 of 12 (permalink) Old 02-07-2010, 03:27 PM Thread Starter
Quoted: 0 Post(s)
Well for now I'm topping it off with Lucas Tranny Fix until I can find someone to fill it up. Pep Boys Midas Jiffy Lube all refused to work on it because it does not have a dip-stick.
Afterwards I'm guessing my only choice is to buy a NEW tranny pan from Atlantic British and pay thier rip off cost of $150.00 for a pan then buy new tranny bolts and screws and pay for new ATF fluid/filter then pay for the mechanic to fix it:
$150.00 = pan
$50.00 = screws
$30.00 = fliud
$60.00 = filter kit
$50.00 = shipping
$150.00 = mechanic
$10.00 = gas to drive to mechanic
TOTAL BEND ME OVER COST SO FAR = $500.00
I just want this gawd-damm leaks to stop...... Tightning the bolts did not work and no telling when I'm going to fry the transmission. So if there is ANYTHING ELSE I'm missing on this list to ensure the leaking from the bolts stops could anyone PLEASE tell me when you get a chance???? I've waited way too long and need to move forward with this thanks.
post #7 of 12 (permalink) Old 02-07-2010, 03:56 PM
Quoted: 0 Post(s)
Whoa! You don't want to add anything that is labeled "fix", any stop leak type product will have a seal swelling agent that will ruin the trans. The only thing you want to add is Dexron III, the cheaper the better as anything labeled Dexron III has to meet minimum specs. The pan can be sourced from a number of used parts places or a local transmission shop can probably get you one with all the bolts and dipstick as well as the filter kit way cheaper than AB. I thought the bolts and cleats were the same from the earlier units, you may just need a pan with dipstick and the filter kit. Have you tried John Gadd (Roverdude)?
Take the truck to a transmission shop, they can probably fix the leak for the cost of doing the fluid and filter service.
osiristheclown is offline
post #8 of 12 (permalink) Old 02-07-2010, 04:04 PM
ReNo111RoVeR's Avatar
Quoted: 0 Post(s)
Why buy a new pan? Is your original cracked?
ReNo111RoVeR is offline
post #9 of 12 (permalink) Old 02-07-2010, 04:10 PM
Quoted: 0 Post(s)
Really, it's not that hard to do yourself. And it will help you to learn your vehicle. Fix isn't a fill. If you went as far to fill it with fix, you could have put anything in there. Please don't drive this too much. You need to get a Rave and track down the leak. There are a bunch of parts sites-RN included-that can help you with tech questions and ordering. IMHO, the only reason you would need new pan is that this one has substained damage. Screws don't cost $50, and the old ones were probably cleanable and reusable. Can't say anything bad about shipping and mech prices. This statement is just my opinion.
1969 LR 109
1970 LR 109 Wagon
1974 MGB
2004 Disco II
vansdonk is offline
post #10 of 12 (permalink) Old 02-07-2010, 07:12 PM
Quoted: 0 Post(s)
He's wanting to swap the pan for the 4HP22 pan with the dipstick.
post #11 of 12 (permalink) Old 02-07-2010, 09:17 PM
Quoted: 0 Post(s)
Oh, I'm under mine so much for offroad checks I guess it's just habit to pull plug on trans and t-case and check. I guess I never thought about putting in a new pan for a quick look. Nice idea.
1969 LR 109
1970 LR 109 Wagon
1974 MGB
2004 Disco II
vansdonk is offline
post #12 of 12 (permalink) Old 02-07-2010, 11:06 PM
Just A Kid Posing As A Middle Aged Man...
spiderfreak80's Avatar
Quoted: 0 Post(s)
Hmm...definitely not a bad idea WLA. I may look into it as well.....
2004 Discovery II "The Grey Goose"--Sold...with regret
3" OME and Toddco Spacer lift, 32" Nittos, TW Shaft, Terrafirma stabilizer, custom winch bumper and sliders, rear camera, CB, 30 GB Zune and Infinity sub.
spiderfreak80 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Can you mix synthetic power steering fluid brands? dubb57 Discovery Series II 4 11-25-2009 05:58 AM
Transmission Fluid Change? Mark Nasso General Land Rover Discussion 1 09-28-2009 09:19 AM
Transmission Fluid babolatboy Discovery Series II 3 06-16-2009 02:58 PM
transmission fluid? disco red rover Discovery Series II 1 03-02-2009 04:19 PM
Transmission Fluid Replacement 01001010 Discovery Series I 6 10-23-2008 07:54 PM
You may post new threads
You may post replies
