SAI solenoid - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 3 (permalink) Old 12-07-2011, 03:00 AM Thread Starter
03DISCOHP's Avatar
Quoted: 0 Post(s)
Garage
SAI solenoid
I replaced solenoid but I am still coding. Which side of the solenoid is which? Does the fitting on side go to the vacuum reserve or the valve? Was done at the same time as a top end tear down, label fell off before being reconnected.
03 Disco S, 71k. Done- rear dif, front driveshaft, 2" OME lift and shocks, Kumho MT KL71, every stinking gasket on the engine and oil pump, wires, plugs, t-stat. Locking TC.
03DISCOHP is offline
post #2 of 3 (permalink) Old 03-28-2017, 04:50 PM
Quoted: 2 Post(s)
Here is a picture of mine, there is two connectors one straight and one 90 degrees, the one showing in the picture is the 90 degrees, the straight one goes to the secondary air valve on the passenger side.
Hope this helps
Ed4x4 is offline
post #3 of 3 (permalink) Old 03-28-2017, 04:58 PM
Quoted: 2 Post(s)
Here is the picture sorry
Ed4x4 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
cdl solenoid kit DiscoDisco Discovery Series II 22 11-24-2008 11:16 AM
Tcase lock out solenoid 64tbolt@gmail.com Discovery Series II 1 10-08-2008 06:50 PM
Transfer Case Lock-out Solenoid 01001010 Discovery Series I 4 09-15-2007 05:17 AM
Transmission Solenoid? JamesVee Discovery Series I 8 01-27-2006 03:25 PM
Fuel cut-off solenoid worms Defender 1 04-04-2005 05:52 PM
You may post new threads
You may post replies
