Ghost Face Killa
O.k., I'll run premium. Disco Mike, I see your statements regarding sea foam. I'm going to run it through this week and will let you know the results. How do you go about cleaning the throttle body and idle control unit?
Hey Guys -
This has been discussed several times in previous threads but often the final technique is not included. I have a 1998 Disco 1. 3 Questions: 1- To Seafoam: pull vacuum line from Brake Booster and use pliers to regulate the Seafoam into engine slowly, Turn off engine for 5-10 minutes. Restart drive around someone else's neighborhood. Hit highway speeds. Correct? 2- How do you go about cleaning the throttle body? 3- How do you go about cleaning the idle control unit? Thanks, Peter |
Suck the fluid in slowly over a minute or too, then as per the instructions let it sit for at least 20 minutes. I know people that let it soak all day for the extra benefit.
Make sure to use the whole can when doing this and put one in the gas tank also. As for the t-body, remove the air intake hose, spray carb cleaner into the t/body and t/plate, scrub the whole area, including the back side of the t/plate with a tooth brush then wipe it all out with some paper towel. Remove the idle control unit, clean all the carbon build up out of it and reinstall. Mike |
| Thread Tools | |
| Display Modes | |
| Sea Foam = No Smoke | DevilDisco | Discovery Series II | 21 | 07-12-2007 07:07 AM |
| sea foam | floridadiscoI | Discovery Series I | 19 | 04-03-2007 06:10 PM |
| sea foam | Zbb6 | Discovery Series I | 18 | 10-28-2006 06:29 AM |
| sea foam | drewclare25 | Discovery Series I | 5 | 07-27-2006 12:07 PM |
| That Sea Foam stuff and isn't there supposed to be something in there? | RageRover | Range Rover Classic | 16 | 03-13-2006 03:25 PM |
