Old 06-15-2008, 11:06 PM   #1 (permalink)
Default seafoam???
I seafoamed my truck this evening, got a ton of smoke but the check engine light wen't on. Is this unusaual? Will it go out after awhile or will I have to get it reset? Thanks tom
tbrisk is offline   Reply With Quote
Old 06-15-2008, 11:49 PM   #2 (permalink)
got mud?
Jupiter Rover's Avatar
I have read that it sometimes comes on and should clear after a few days.
DII
-- Pete
285/75 r16 Destination M/Ts
Old 06-16-2008, 06:22 AM   #3 (permalink)
brooksa's Avatar
Mine stayed on after I seafoamed, had to get it cleared.
2004 DII SE7
brooksa is offline   Reply With Quote
Old 06-16-2008, 07:31 AM   #4 (permalink)
The light will come on usually after pushing to much fluid to fast, usually it will go off after a 4 or 5 start cycles, if not, as already mentioned, it is off to the local auto parts store to get it cleared.
Did you also clean your t/body and iodle control unit?
Old 06-16-2008, 10:03 AM   #5 (permalink)
no. how do you clean the t-body??
Old 06-16-2008, 10:33 AM   #6 (permalink)
Steph's Avatar
I think that one the most important purchases one can make after buying a rover, is an OBD2 reader. For $150.00, you can get one that will give you the codes with its description and allow you to reset your computer. That way, no matter where you are or what time it is, you don,t have to rely on anybody else.
Knowledge is only really worth anything when its been experienced first hand. If you heard it from a guy who heard it from a guy.....nevermind and keep it to yourself.
Steph is offline   Reply With Quote
Old 06-16-2008, 10:35 AM   #7 (permalink)
jmrivera's Avatar
I thought that a standard OBDII reader was not very useful on the Discovery??? What's the consensus???
Jonathan
jmrivera is offline   Reply With Quote
Old 06-16-2008, 10:43 AM   #8 (permalink)
Nearly any OBD2 scanner will pull codes from Rover, the more expensive gives you alot of extra feature that most people won't use.
To clean the t/body, remove the air intake hose, pushing it off to the side, look inside the t/body, see all the black build up, spray it with carb spray, open the plate spraying on the back side, scrub with and old tooth brush and wipre out with some paper towel.
Engine Cleaning and Seafoam Pedro_malo Discovery Series I 3 05-27-2008 07:55 PM
Where to put Seafoam in '03 Discovery 4.6L??? jmrivera Discovery Series II 11 05-09-2008 10:57 PM
real quick seafoam question, i searched just double checking. Jupiter Rover Discovery Series II 8 04-29-2008 03:14 PM
Where exactly is the pcv tube to suck in seafoam? ajguida Discovery Series II 6 03-28-2007 07:41 AM
Used Seafoam this past weekend... 2002DiscoII Discovery Series II 6 01-24-2006 09:39 AM
