Links
Old 08-02-2006, 03:00 PM   #1 (permalink)
Default Seat problem???
Have a seat problem that just started....
Moved the passenger seat ahead a bit to flip the rear seat, than moved it back after resetting the seat. As i was driving home the seat started to move forward by itself??? So i stopped and pushed the button so it would go to the rear most position [which it did] but when i go to move it forward now it only goes about an inch then stops, it will go back again but the more you use it the less and less it moves to the point it stops???
-I checked the switch, it's o/k....
-tested with the drivers switch....same result as occurring problem, so it's not in the switch
Could it be the motor??? Does not seam likely but....?????
Thanks, Dean
6cuda6 is offline   Reply With Quote
Old 08-02-2006, 04:03 PM   #2 (permalink)
Every so often my pass-said seat will not work right. Its never done anything on its own, but has had the other issues with not moving forward as it should.
All I can tell you is that mine must be bad connection because if I move the wiring harness a bit it will work. Doesn't do it often, but if I give it tug and a wiggle , it seems to take care of the problem.
stb616 is offline   Reply With Quote
