Old 05-24-2008, 08:11 PM   #1 (permalink)
Ghost Face Killa
kkahao1's Avatar
Default Separator
Saw somebody talking about clogged separator causing leaks in valve covers and intake gasket. I was going to replace the valve cover gaskets until I realized the hell of a job it was...all I have to compare it to is my 84' Blazer. Had the valve cover gaskets replaced and have a leak on passenger side. How do you unclog a separator and where and what the hell is it? Disco Mike also talked about cleaning out my engine...Sea Foam? If so, I saw a picture of a previous post. Is the application point at the nipple on the intake manifold or the passenger side of the valve cover gaskets?
Thanks
kkahao1 is offline   Reply With Quote
Old 05-25-2008, 05:57 AM   #2 (permalink)
What year and model?
Oil Separator PCV System ichibanCA Discovery Series I 2 01-21-2007 08:55 AM
how to remove oil separator rjlsierra Discovery Series I 4 04-27-2006 06:36 PM
