Serpentine belt change. - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 17 (permalink) Old 03-20-2008, 05:00 PM Thread Starter
Owner Since 98
2Discos95-00's Avatar
Quoted: 0 Post(s)
Hello fellas, I am changing the belt this weekend and wanted some quick pointers from you guys. Anything special i should watch out for? Loosen the alternator first? Anything else i should replace? Also Does anyone have a diagram of how the belt runs (i got a feeling i will need it)? Thanks guys.
4.0. no ace, no sls.
2Discos95-00 is offline
post #2 of 17 (permalink) Old 03-20-2008, 05:24 PM
PeteRice's Avatar
Quoted: 0 Post(s)
Driver manual may show...if not you can draw it up before you take off the old one...or take a picture, but that'd be a funny angle I guess.
2000 Land Rover Disco II
My Disco's a bush truck. Wtf to I care about scratches?
PeteRice is offline
post #3 of 17 (permalink) Old 03-20-2008, 05:39 PM
Former LR tech, Albany NY
Quoted: 0 Post(s)
huh, the belt runs off of a tensioner.
pull the tensioner to the driverside and it lets off the tension.
I used to work on Rovers. Got a question just ask, need a Rover looked at, Albany, New York.
Rovin4life is offline
post #4 of 17 (permalink) Old 03-20-2008, 08:21 PM
'00 DII Member
auwesman's Avatar
Quoted: 0 Post(s)
yeah, just pull the tensioner. I wouldn't worry about loosening the alt...real easy job. Even eaiser if you have someone to help pull the tensioner while you thread off and on, but it can be done alone.
I think my rover has a photo of how the belt runs on the front end under the hood....or maybe thats the tacoma...
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline
post #5 of 17 (permalink) Old 03-20-2008, 09:00 PM
2002 Discovery II SE
Alak's Avatar
Quoted: 1 Post(s)
I just screw around until I find the proper arrangement.
OR if I remember, I take a permanent marker and accually draw under the hood somewhere the way it goes. Because odds are if you absolutely have to change the belt, you wont have a diagram (unless theres one under the hood).
I also always keep an old belt with me in the boot.
Alak is offline
post #6 of 17 (permalink) Old 03-21-2008, 01:43 PM Thread Starter
Owner Since 98
Quoted: 0 Post(s)
Thanks guys. Im done before the weekend even started.
post #7 of 17 (permalink) Old 03-22-2008, 06:54 AM
New Yawker in California
RudemanRB's Avatar
Quoted: 0 Post(s)
Good idea, keep the old belt. you never know in a pinch if your off road somewhere and you get screwed, when I change my belts. I compare the old belt with the (last old belt)
and which ever looks better becomes my new spare.
Rudy
RudemanRB is offline
post #8 of 17 (permalink) Old 03-28-2008, 02:32 AM
garywinter's Avatar
Quoted: 0 Post(s)
Diagram
These may help you.
[/SIGPIC]
99 Discovery 2 XS V8
Terrafirma Coil Springs All Around
Replacement Front Bumber
Dastek Unichip
BFG All-Terrain Tyres
Front Runner Roof Rack
Snorkel
garywinter is offline
post #9 of 17 (permalink) Old 04-02-2009, 05:25 PM
Truth > Freedom
Chazz Layne's Avatar
Quoted: 2 Post(s)
Yay old thread... this is the only one the search gave me of any relevance.
I'm guessing the design has changed somewhat for the 2004 4.6L? There are no pulleys that can simply be "pulled" towards any side of the vehicle - they are all fixed. I have the "tensioner" (according to RAVE, but I call BS) off (literally), and there is no way in hell that thing is going back on there (I would have to stretch the belt an inch to do so).
Now the bracket the tensioner is on could perhaps be turned if I loosened the 13mm bolt holding it on, but RAVE is saying: no, I should only be touching the 15mm on the pulley itself?
RAAR... help?
Chazz Layne |
Chazz Layne is offline
post #10 of 17 (permalink) Old 04-02-2009, 05:54 PM
Truth > Freedom
Quoted: 2 Post(s)
Originally Posted by Chazz Layne View Post
Now the bracket the tensioner is on could perhaps be turned if I loosened the 13mm bolt holding it on...
No go there either, at least I know it is on tight now... WTF...
Chazz Layne |
post #11 of 17 (permalink) Old 04-03-2009, 01:37 PM
Truth > Freedom
Quoted: 2 Post(s)
I've pulled what RAVE called the tensioner's bracket to find it an assembly that looks like it SHOULD allow me to rotate the arm with enough force, but it appears to be seized. I will be one with the PB Blaster in a few moments, but first I wanted to make sure I'm not about to totally screw the thing up...
Am I on the right track here? This is the part in question...
Working on trucks in a sand storm... not fun.
Chazz Layne |
post #12 of 17 (permalink) Old 04-03-2009, 10:25 PM
Truth > Freedom
Quoted: 2 Post(s)
Answered my own questions on this one. Yep I was on the right track, yep it was just seized. PB Blaster to the rescue (took 2 treatments), belt done, remaining squeaks gone, and strange idle issue gone.
Chazz Layne |
post #13 of 17 (permalink) Old 01-16-2011, 06:32 PM
Quoted: 0 Post(s)
So frustrating! Threw the serpentine belt on 1999 disc 2. Figured out how to thread new one....can't find tensioner...where is it...passenger side, driver side, smooth or with grooves. All Data says use 15mm....loosened that and won't move...loosened every other pulley...nothing moves...Help!
parplyr is offline
post #14 of 17 (permalink) Old 01-17-2011, 04:15 AM
Quoted: 1 Post(s)
Passenger side below the alternator, you can't miss it. Maybe it needs a bit of PB blaster.
Bosbefok is offline
post #15 of 17 (permalink) Old 01-17-2011, 10:17 AM
Quoted: 0 Post(s)
Ok...grooves or smooth? And I think I need to crank it clockwise not undo the bolt...most instruction in alldata is pretty vague
parplyr is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
ACE serpentine belt length?? LANDY96 Discovery Series II 3 02-22-2008 04:51 AM
200 tdi cam belt change jimllshiftit Discovery Series I 0 09-16-2007 09:09 AM
300TDI belt change Blade boy Discovery Series I 0 05-28-2006 02:05 PM
serpentine belt me.guevara Discovery Series I 3 01-01-2006 03:52 PM
Replacing Serpentine Belt totallymann Discovery Series I 5 08-21-2005 01:05 PM
You may post new threads
You may post replies
