Old 04-14-2008, 12:55 PM   #1 (permalink)
Rycymru's Avatar
Default Service Engine Light P1884
I recently bought an 03 Discovery and have had alot of sensors go off lately, i've fixed all of them except one that just came up. P1884, when autozone checked the computer, this code came up and said it was a transmission code. I have checked around and one site said the code was "CAN message WFPDK (DKI) invalid (FFh)."
Does anybody know what this means and how do i fix this. Thanks.
-Ryan
2003 Land Rover Discovery II
Rycymru is offline   Reply With Quote
Old 04-14-2008, 01:12 PM   #2 (permalink)
'00 DII Member
auwesman's Avatar
P1884 -
coolant level sensor short circuit
From what I have read it has to do with one of the following:
Engine friction
throttle position
engine temp
road speed
engine torque
engine speed
engine air intake temp
Is this your only code? What codes did you have previously and how is the truck running?
Could be the crank sensor but this code gets tossed around in forums and seems to have different symptoms.
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline   Reply With Quote
Old 04-14-2008, 02:19 PM   #3 (permalink)
Rycymru's Avatar
I had the codes: P0112, P0102, P1412, P1415, P1884. But after i did a few things they went off except for P1884.
The truck is running great now, i had a hose that was loose on the intake and another hose that came off, i put them back on and tightened the clamp and the car runs great. I believe that was the reason for the "too lean" codes.
Old 04-14-2008, 02:33 PM   #4 (permalink)
Elemental's Avatar
Sounds like you need a new CAN.....Easy to get at Autozone.
When I was done with her, her bed needed Shamwow sheets!
Old 04-14-2008, 02:45 PM   #5 (permalink)
An invalid CAN message usually relates to low battery voltage,poor earth or a loom fault - not always easy to find.Have a look where the loom goes around the back of the transfer box then down to the WXYZ switch on the side of the gearbox.
buick215 is offline   Reply With Quote
Service Engine Soon light! Help need advice! (long) champagnerange Discovery Series II 11 10-13-2007 06:16 AM
[D2] Service Intervals rmuller Tech & DIY 1 05-10-2007 10:11 PM
Service Engine Light elanghout Discovery Series I 2 10-07-2006 03:36 PM
Service Engine Soon light on urgent smileyq Discovery Series II 15 07-19-2006 10:23 PM
Service Engine Light 1999 Discovery SD Patrick52 Discovery Series I 9 07-20-2005 01:03 PM
