2004 Discovery II driver
Ok, my first malfunction with my rover. Its a 2004 Disco II SE7 with 20,900 miles and its oil was changed 1 month ago.
I am about 90% sure I fixed the problem and its no big deal..but i wanted some input. I filled my gas tank 3 weeks ago (i'm only down to a half tank now becuase I hardly ever drive). Well today it got down to a half tank and as i was driving home from dinner my Service Engine Soon light came on. I got home, opened the manual and popped the hood. I figured it was my gas cap, well i checked it and it was loose (which the manual says is the most common issue). Tightened it up and checked my fluid levels for good measure. I know the light will not turn off with out a dealer turning it off, but I wanted to know if there might be anything else I can check before I go to the dealership (I know it seems paranoid...but i love my rover too much). Also...Are there any tuners/scanners/computer diagnostic tools available for sale for the 4.6L V8 Disco IIs? if so where can I buy one? And What computer port does the land rover's have, i.e. OBDII or OBD ports? The reason I ask is because I had diablosport predator and a sct xcaliber II scanner for the OBDII port for my old 2005 V Supercharged mustan...and I always used them to look at my problems before a dealership checked my car.
![]() 2004 Discovery II SE7 - My Ride 2006 LR3 SE - Dad's Ride |
'00 DII Member
If it was the gas cap, the light will go off on its own. usually takes 2-3 fill ups.
One thing you can do is go to the local Autozone and have them check the codes for free. Get the codes and post them. Autozone will also clear your CEL light for free if you ask them to. Or just buy one while your there. They range from $20.00 to $3,000.00. Just get one that can clear the codes. An OBDII scanner will read codes for any car built '96(?) or later. If I were you, I'd just buy one. Chances are excellent you'll need it eventually. ![]()
'00 DII '07 Toyota Taco War Eagle! |
