» Featured Product
» Sponsors
» Sponsors
LandRoversOnly.com is the premier Landrover forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 11-22-2009, 07:36 AM   #1 (permalink)
Default SES Light Flashing
So I have the service engine soon light is now flashing. The engine has a very rough idle and kind of shakes the truck some. Should I drive it to autozone to get the codes read or no? Maybe tow it?
johnfields20 is offline   Reply With Quote
Old 11-22-2009, 07:44 AM   #2 (permalink)
DiscoDream2's Avatar
Drive it if it's close, real close. The tow will cost more than it would to go buy an OBDII scanner....get the codes and report them back here for help.
DiscoDream2 is offline   Reply With Quote
Old 11-22-2009, 07:50 AM   #3 (permalink)
well its like 12 miles
Old 11-22-2009, 08:23 AM   #4 (permalink)
UGH - a few blocks but not 12 miles. Try to find a friend that has an OBDII reader..manual says don't drive with a blinky SES...or go buy one...it will pay for itself in the end and you will use it alot..@ $69 for a cheap one vs a $99 tow.
Old 11-22-2009, 09:28 AM   #5 (permalink)
Ok I went to Autozone and borrowed their scanner. All they charge is a security deposit of $150 if anyone is wondering. Heres the codes I got.
1) P1300- Misfire...
2) P0306- Misfire cyl 6
3) P0301- Misfire cyl 1
4) P0300- Random Muiltple Cyl Misfire
5) P0301- Misfire cyl 1
6) P0306- Misfire cyl 6
So where do I go from here.....spark plugs or wires but im thinking ignition coil went bad or is going bad.
Truck only has 34k miles
Old 11-22-2009, 11:09 AM   #6 (permalink)
So from searching the forums....start with magnecor or kingsborne 8mm wires then go from there. Champion or bosch spark plugs as well.
Old 11-23-2009, 11:53 AM   #7 (permalink)
Well I am changing the spark plugs now with champions. I have ordered the wires they should be overnight here tomorrrow. So wish me luck that this fixes the issue.....
Old 11-23-2009, 12:11 PM   #8 (permalink)
nasa25's Avatar
because of the fact that the ses was consistently blinking I would tend to lean more towards a bad coil, but for sure change the plugs and wires and see what happens.
nasa25 is offline   Reply With Quote
Old 11-23-2009, 12:41 PM   #9 (permalink)
I agree I think its a coil to. since 1 and 6 are on the same coil.
Old 11-23-2009, 12:43 PM   #10 (permalink)
Administrator
Are you running factory wires, if so do a full tune with 8 mm wires first, if it is still there then replace the one coil.
Old 11-23-2009, 02:22 PM   #11 (permalink)
Yea I know Mike I ordered the kingsborne wires today overnight to me tomorrow. Then I get to tackle that one.
Old 11-24-2009, 10:36 AM   #12 (permalink)
Anyone want to give me some suggestions on getting out that alluminum tube connecting the SAI.
Old 11-24-2009, 10:46 AM   #13 (permalink)
Hope this helps..
Old 11-24-2009, 10:56 AM   #14 (permalink)
thanks but im just trying to get out a alluminum tube that connects the two and runs across the top of the coils. Its just a really really tight fit and its kickin my tail.
Old 11-24-2009, 12:22 PM   #15 (permalink)
Administrator
What octane gas are you burning?
May also want to to an induction cleaning to get rid of a little carbon?
Disco I SRS light flashing & what position to run 4WD lubli23 Discovery Series I 4 11-18-2009 04:57 PM
Engine Light Flashing with Multiple Misfire codes WLADiscoII99 Discovery Series II 14 08-23-2009 07:23 PM
hiccup and flashing service engine light beej414 Range Rover P38, Mk III and Range Rover Sport 2 08-22-2009 11:42 AM
M&S light on, "D" flashing... msggunny Discovery Series II 22 06-21-2009 11:26 PM
(S) Trans Sport mode light flashing Disco Xpedition Discovery Series II 15 04-17-2008 05:04 AM
SEO by vBSEO 3.3.2
