Old 11-29-2006, 06:30 AM   #1 (permalink)
02DISCOBLK's Avatar
Default sloppy steering at times
I needs some help on my steering. At times while driving the car will travel into the ruts in the road. If you are going over a bridge that is not smooth the steering wheel will move back and fourth, when you enter on to the bridge and exit off the bridge. Has anyone had this concern before. HELP!
-2001 BLACK DISCOVERY SE II
-REAR LAMP GUARDS
-OFF ROAD LIGHTS
-LR SEAT COVERS
-BORLA EXHAUST
-OME 3'' Lift
-WINCH
-FUTURE-
-DIFF. LOCK
-Rock Sliders
02DISCOBLK is offline   Reply With Quote
Old 11-29-2006, 08:16 AM   #2 (permalink)
First look at your air pressure, tread wear, and toe setting.
How many miles on your truck?
Old 11-29-2006, 09:09 AM   #3 (permalink)
02DISCOBLK's Avatar
All tire psi is good, tires are less that 7months old. have not checked toe setting,but the car does not seem to be pulling or doing anything funny. Only when roads are bad or rough entrance and exit bridges. my truck has
87,000 miles on it. 2001 not 02
-REAR LAMP GUARDS
-OFF ROAD LIGHTS
-LR SEAT COVERS
-BORLA EXHAUST
-OME 3'' Lift
-WINCH
-FUTURE-
-DIFF. LOCK
-Rock Sliders
Old 11-29-2006, 11:27 AM   #4 (permalink)
Does your steering wheel sit perfectly level?
One other possibility with your mileage would be the steering stabilizer, it has to be shot by now, time for a good OME stabilizer.
Old 11-29-2006, 11:44 AM   #5 (permalink)
Polish and proud of it.
TsiArt's Avatar
I have a problem with sterring .
It get progresivly more slapy when the wheel it turned to the left .
In the center it has maybe 1/4" of slap . but at full left it has at least 3 to 5" of slap .
That's the stering box , right ?
I'm a Proud owner of a vehicle that has a turning Radius of 747
Check out our Frappr!
Myspace ? It dose not mather who votes, only matters who counts the votes _ Krushchew
TsiArt is offline   Reply With Quote
Old 11-29-2006, 12:01 PM   #6 (permalink)
02DISCOBLK's Avatar
yes it does drive straight except on road with a bad crown,(like by my work) shorly after i got the truck about a year ago I put a new rancho stabilizer on it. could be posible that it is just as weak. (not very strong)
-REAR LAMP GUARDS
-OFF ROAD LIGHTS
-LR SEAT COVERS
-BORLA EXHAUST
-OME 3'' Lift
-WINCH
-FUTURE-
-DIFF. LOCK
-Rock Sliders
Old 11-29-2006, 12:05 PM   #7 (permalink)
Sounds like your steering box is going south, how long has it been since you changed the fluid?
Old 11-29-2006, 12:07 PM   #8 (permalink)
Time to run it by an alignment shop that is used to doing 4wheel alignment, have then inspect and set the toe.
Old 11-29-2006, 12:09 PM   #9 (permalink)
02DISCOBLK's Avatar
I was afraid of that. $$$$$ I will try get the alighnment done asap. Thanks
-REAR LAMP GUARDS
-OFF ROAD LIGHTS
-LR SEAT COVERS
-BORLA EXHAUST
-OME 3'' Lift
-WINCH
-FUTURE-
-DIFF. LOCK
-Rock Sliders
Old 11-29-2006, 01:09 PM   #10 (permalink)
bama's Avatar
while we are talking about steering, at times when turning right i get a whine coming from the engine sounds like powersteering pump, i need some direction on service for the powersteering system, and how much fluid to add, if doing a flush
bama is offline   Reply With Quote
Old 11-29-2006, 01:55 PM   #11 (permalink)
Bama,
May want to consider flushing the power steering system to free up a possible stuck valve.
PM me with you tele number and a good time to call and I'll call you.
Old 11-29-2006, 01:59 PM   #12 (permalink)
If your alignment is off, that is not a big expense compared to other Rover repairs.
Old 11-30-2006, 10:13 AM   #13 (permalink)
TsiArt's Avatar
I've changed it twice .
Once i got it . ( May of 2006 I think or 2005) and last month when I had the motor out of the truck
