Old 11-27-2006, 10:21 PM   #1 (permalink)
Default Sloshing Sound
I read in the past about a water sloshing sound. I don't know were it is comming from. Can anyone give me some clue as to what it is and what I can do to get rid of it?
cheers
disco2inblue is offline   Reply With Quote
Old 11-27-2006, 10:35 PM   #2 (permalink)
salty's Avatar
it's probably in the ac unit. Look to see if the drain nipples under the car are clear, make sure not to get a face full if they are blocked! They are up by the center differential.
Just a side note I had a warning triangle with a sand filled base that made the same sound, it took me weeks to find it, I just wanted to mention it as an alternative.
Jim
salty is offline   Reply With Quote
Old 11-28-2006, 06:51 AM   #3 (permalink)
When do you hear the sloshing sound, when you turn left ot right or when you give the engine a little gas?
As already mentioned, it could be water trapped in the a/c, if that is the case, your front carpets should also be getting bet.
The other possibility is you have air trapped in your cooling system caused by either a coolant leak or failing head gaskets.
Check you truck over and get back to us.
