2004 Discovery II driver
Title error: small leak INTO cab thanks to genuine ladder (my bad i was rushing)
ok, so i have a small leaking issue. its not serious, and totally manageable. If my car sits in the rain for a while, i start up and i go forward, all the water just sitting on my roof pours of the back. but (thanks to my newly dealer installed and purchased Genuine Parts Ladder) a teaspoon or so drips through the rear doors weather stripping onto my retractable cargo cover. the weather stripping is perfectly fine, i think the dealership didn't tighten down the screws enough (as too seeing that they aren't flush with the top of the rear door's lip). I am gonna try and see how tight the bolts are (After it stops raining, probably this weekend). I was just wondering if any other discos have had this problem with a genuine ladder?
![]() 2004 Discovery II SE7 - My Ride 2006 LR3 SE - Dad's Ride |
I have this exact same problem and, in fact, it is one of the things it is going in for tomorrow. The ladder's been on for a few month, plenty of time for the seal to re-form I should think, and still leaks. I'll let you know what they say.
okey dokey. i wont be able to go to a dealership in march, unless i someone am gonna spend some time in Birmingham or ATL with my car. good thing it doesnt rain as much in AL as it does at my home in FL
Had this issue when I first got my discovery with the OEM ladder already on. I too tought it was the ''thickness'' of the ladder that was allowing water to go in. Went to the dealer, and the service manager who is also a member of the local club, showed me how to resolve this.
You first have to open the door all the way, and while a second person is holding it and not allowing it to move, you have to loosen the upper hinge. Then the second person lifts the wide open door a little to allow the hinge to move in further than it originally was. thighten the upper hinge, and this will create a thighter seal. Worked for me. |
sounds good man, thanks for your help! I may try it out this weekend. what hand tools do i need to hit up the door hinge bolt? any certain size thank you can think of offhand?
These sites are about sharing info, and letting others profit from our experiences. Happy I could help.
To see if the seal is tight enough, you can use a regular sheet of paper and put it half way in on top of the door and close it. You shouldn't be able to pull it out easily. You should have a lot of resistance, almost to the point of ripping the sheet. Then, jump in, close the door and have someone hose the heck out of it. Shouldn't leak anymore. |
i may end up making it tighter later. but it has rained the past few days and i havent noticed any water inside the cab. althought some of the weather stripping was still a big wet, nothing came close to dripping in.
| Thread Tools | |
| Display Modes | |
| Small Coolant leak...Blow Head Gasket? | maverick544 | Discovery Series II | 9 | 09-22-2007 09:27 AM |
| What's up with that rover oil leak thing??? | Steph | Discovery Series II | 16 | 09-02-2007 11:37 PM |
| craziness with the exhaust leak | ealex | Discovery Series II | 4 | 05-18-2007 07:41 AM |
| Small leak | Cdawg09 | Discovery Series I | 7 | 02-27-2006 08:58 PM |
| 1999 4.6 needs some work; fix or sell? | Spring | Range Rover P38, Mk III and Range Rover Sport | 17 | 01-29-2006 02:18 PM |
