Sounds Like a Vacuum Cleaner - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 8 (permalink) Old 01-03-2010, 05:56 PM Thread Starter
Quoted: 0 Post(s)
I have a random noise usually at a stop, or at least I can hear it then. Coming from under the hood sounds like a vacuum cleaner running. Goes away and is very random. Any ideas? I have no dummy lights on and everything seems to be on good operational order.
Ponce is offline
post #2 of 8 (permalink) Old 01-03-2010, 06:03 PM
JAKD-UP's Avatar
Quoted: 2 Post(s)
It's your secondary air for your 02censors
JAKD-UP is offline
post #3 of 8 (permalink) Old 01-03-2010, 06:16 PM
lipadj46's Avatar
Quoted: 0 Post(s)
+1 SAI, it will kick on when your exhaust temp is low, check all the hoses for a leak also. Should mostly kick on when you start your truck. There is a black plastic pump and a tin can looking thing (hooked up to the passenger head/exhaust manifold) that is your SAI system.
2002 DII 114,000 miles
lipadj46 is offline
post #4 of 8 (permalink) Old 01-04-2010, 08:35 AM
DiscoDream2's Avatar
Quoted: 1 Post(s)
X3 check any connections for leaks if it is too loud.
DiscoDream2 is offline
post #5 of 8 (permalink) Old 01-06-2010, 06:19 PM Thread Starter
Quoted: 0 Post(s)
My secondary does seam loud, just put engine back together a few weeks ago. But this noise is seriously the same sound as a vacuum cleaner motor. Never heard it before in the 4 years I have had this truck it is very strange. No codes at the moment.. It will do it when the motor is hot.
Ponce is offline
post #6 of 8 (permalink) Old 01-06-2010, 06:22 PM
JAKD-UP's Avatar
Quoted: 2 Post(s)
I wouldn't worry about it much I took mine off and plugged the hole
JAKD-UP is offline
post #7 of 8 (permalink) Old 01-06-2010, 06:28 PM
laments the death of industrial strength soup sporks \;/
Ultraviolet's Avatar
Quoted: 0 Post(s)
you had sai? what year do you have, i forgot.
I am the White Rabbit
Ultraviolet is offline
post #8 of 8 (permalink) Old 01-06-2010, 06:32 PM
JAKD-UP's Avatar
Quoted: 2 Post(s)
02
JAKD-UP is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
throttle body cleaner Colton5476 Discovery Series II 4 10-13-2009 06:45 AM
Injector Cleaner advice needed, please. DenverCurmudgeon General Land Rover Discussion 8 06-13-2007 04:35 PM
Best wheel cleaner smileyq General Land Rover Discussion 16 10-31-2006 04:37 AM
How often should u use Seafoam and Redline system cleaner? Jupiter Rover Discovery Series II 6 10-03-2006 07:48 AM
Need a good engine cleaner disco12 General Land Rover Discussion 5 06-18-2006 09:34 PM
You may post new threads
You may post replies
