New Land Rover Owner
Do you guys recommend replacing the gasket when replacing the spark plug wires on a 2002 Disco II? I was told by the dealer that they don't replace the gasket, but I have read on other sites that it is recommended. This site seems much more informative. Any help would be great, as I am new to the Land Rover scene, had my truck for about 3 weeks.
Super Moderator
Welcome to Land Rovers Only!
What gasket are you referring too?
Land Rover-less. -------------------------------- 2006 Infiniti QX56 - Loaded 2002 Discovery II SE - SOLD! 1999 Audi A6 Avant Quattro Tiptronic - Slammed on RS4 18's 1996 Mariah Talari w/350 Mercruiser and Ron Hill Marine Go-fast parts.(Presently in Dry Storage) |
#3 (permalink) | |
Super Moderator
huh.. you know, I am not sure. I thought you just had to be double-jointed to reach the coils.
Otherwise known as STEVE
I changed mine without pulling the plenum. I just moved the hoses on the firewall out of their mounts to gain access. Not a fun project, but it works. If you remove the plenum, then some sensor safe RTV can reseal it and that's what most shops will use. The upper plenum cover is only just an airbox, so it's not anything exotic.
#6 (permalink) | |
so in other words if I remove the wires along the firewall I can reach the spark plug wires easily enough to not remove the plenum? That would be best if I can do that. Because I really don't want to remove the plenum if not necessary. |
that's what we did... still skinned some knuckles too.
#8 (permalink) | |
I am also using 8mm Magnacor wires along with Bosh Platium Plus 4's, and the difference is hugh. You will notice alot more low end torque because of the additional spark generated. Good luck, Mike J. |
#9 (permalink) |
Its easier to remove the upper plenum.
The upper part isnt prone to leaks at all. No oil or coolant going thru it. No use in replacing the upper one. its paper anyway. It makes it easier to remove the plugs. also check the vehicle over for leaks. if you have an intake leak then you have to remove alot more stuff. it aint hard takes a few hours. |
#10 (permalink) |
Super Moderator
Does anyone have pics of what it tooks like to remove the upper plenum?
#11 (permalink) |
2000DiscoII
I've tried to fit my hand behind the plenum and cannot do anything except touch the wires where they connect to the coil packs. I moved the wiring harness but the are several tubes/pipes running along the firewall that don't allow me to grab ahold of the end of the wires. I thought I saw some directions on this forum for removing the plenum but I cannot find them now. It looks like you need to remove the throttle assembly and other stuff bolted onto the plenum, and then there are four bolts securing it. Any instructions greatly appreciated. 2000 Discovery II, 88,000 miles with original wires. I want to replace with the 8mm Magnecors I just got.
We drove about a thousand miles last weekend and the exhaust/tailpipe was growing a black mustache from carbon build up on it. I have done the Sea Foam treatments in the tank and through the intake, but I'm sure the wires need replaced. Thanks, JDB |
#13 (permalink) |
plugs are simple. lr recommends at 60k
wires are not, . If the wires arent causing a misfire dont bother at all. They aint easy and a royal pain. In order to do them it depends on the thickness of the persons hands and time they have. of course you can always remove the upper intake. trust me nothing sucks worse then one or two wires bad on a waiter. Do you have any idea how hot the intake and other stuff gets. |
#14 (permalink) | |
Factory wires are only good for about 37,000 volts anyway, Magnacor can handle 55,000 volts, and the more volts, the better plugs you can run and the more power you will have as well as gain in MPG. A set of 8mm Magnacors and Bosh Platium Plus 4's and you will have a hugh increase in low end torque. Change them. Mike |
