Old 11-02-2004, 06:58 AM   #1 (permalink)
John's Avatar
Default Sqeeky peddle
This problem relates to a 04, TD5, manual box.
When depressing the clutch peddle it squeaks. It is quite difficult to reach from the under side and I wondered if it’s accessible from the engine compartment.
I tried the gynie approach and stuck a wad of silicone grease on the ends of my fingers to try and lubricate the pivot points and rod but as this is all done by feel I can't be sure I got to the right places.
It’s still squeaking so I guess I must be doing something wrong.
Any ideas as it's driving me mad?
John is offline   Reply With Quote
Old 11-02-2004, 07:39 AM   #2 (permalink)
Go back to the dealer.
Old 11-02-2004, 12:00 PM   #3 (permalink)
Sounds like a rusty inner pivot.
If that's the case, it'll b not 2 serious, but that noise can drive u mad in seconds.
When I find this problem, I spread a little bit of spray grease (silicon type chain lube is good) with a straw applicator on the can, u've 2 b careful of not spreading grease in the clutch pack (I mean very careful)
U've 2 apply the grease in every friction point, sometimes u'll need to reach some of them that r inside the bell housing, so u may need a very long straw.
Just a bit of grease will b enough, just try 2 get it away from the clutch pack.(Very important)
Anyway u can lube the paddle assembly, just in case.
Good luck.
Kaliman is offline   Reply With Quote
Old 11-02-2004, 01:37 PM   #4 (permalink)
Every squeaky clutch pedal i have done so far has been either the the return spring on the pedal or the pedal box. Large flat blade screwdriver to ease the spring to one side a little and a long thin flat blade with a small dab of grease,frustrating but ultimately satisfying!
scoobymick is offline   Reply With Quote
Old 11-02-2004, 03:24 PM   #5 (permalink)
beer drinking member
dent's Avatar
i'm with steve.. if it's an '04 should still be under warranty so why do the work yourself when you can take it in.. sit back have a pint and pick it up later then ask, 'so what was wrong with it and what did you guys to do fix it'
I know this doesn't help much but... my 2 cents
take care
sam
dent is offline   Reply With Quote
Old 11-02-2004, 04:43 PM   #6 (permalink)
take care
sam
You're quite right, i didn't notice it was an '04,i'm one of the guys who end up doing it so i look at the problem from a slightly different angle
Old 11-03-2004, 02:31 PM   #7 (permalink)
dent's Avatar
aaahhh.. mechanic are you... to bad you're not in my neck of the woods. would have bought you a case or maybe a keg to help/ do a valve job
take care
sam
Old 11-03-2004, 04:17 PM   #8 (permalink)
Trust me i wouldn't mind being in your neck of the woods,make a nice change from the UK. A mate of mine emigrated to Canada this time last year,he's in the Winnipeg area,lucky b*stard!!
