Old 11-12-2007, 06:58 PM   #1 (permalink)
Default SQQQUUUEEEKKKYYYYY Brakes, Help!!
Need a little help here. Our Disco's brakes are squeeking every time we come to a stop...well, not every time, but it's dang sure close to every time. What's the deal? Do we just need new pads? On my Tahoe the brakes are set up so they squeek to give a warning before it's time to replace them...then they stop squeeking after a couple hundred miles and you know it's time to replace them. Any and all ideas are welcome? The car has 59,000 miles on it and it's a 2002 SE7. We bought it with 45,000 miles on the car and to my knowledge the brakes have never been replaced. Thank you in advance.
IWANTADISCO is offline   Reply With Quote
Old 11-12-2007, 07:16 PM   #2 (permalink)
At 45,000 miles, they have been replaced and most likely with some cheep pads, probably with no sound deadening material being applied to the backs of the brake pads.
Time to consider starting over before you throw an ABS fault on top of the noise.
Old 11-12-2007, 07:41 PM   #3 (permalink)
2004 Discovery II driver
i've got the same issues on my rover. I am at 21k miles with the original or warranty replaced brake pads in the front and I am getting the squeaking too. I'm gonna have the dealer check the crap out next week when they replace all the other warranty parts i have....the great thing about this warranty i have, everything is covered (except oil changes) until 2009.
stolenheron is offline   Reply With Quote
Old 11-12-2007, 08:58 PM   #4 (permalink)
'00 DII Member
auwesman's Avatar
The easiest solution is to just pull the pads and spray the backs down with "brake squeel." It's a very tacky spray that dampens the vibration that causes the noise. Use it LIBERALY (I think it will even tell you to on the back of the can). That would be the cheapest solution, a can of the stuff is like $8.00 or something like that. I had a Ranger that had horribly noisy brakes and brake squeel fixed it every time.
Worth a shot, if that doesn't work then you may be looking at better pads (akebono, kevlar, etc.) But hey, what's $8.00 and an hours work?
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline   Reply With Quote
Old 11-13-2007, 06:25 AM   #5 (permalink)
troverman's Avatar
I had this problem on our 2000 Discovery II. The squealing was very embarrassing, and we bought anti-squeal paste you squeeze out of a tube and applied it to the back of the pads per the instructions. It worked!
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rovers:
1995 Range Rover 4.0SE
Old 11-17-2007, 09:30 PM   #6 (permalink)
crl
crl's Avatar
You can use sand paper on the discs to scuff them up a bit if they have become glazed which can also cause squeaking.
crl is offline   Reply With Quote
Old 11-18-2007, 06:15 AM   #7 (permalink)
The main thing is buy good pads and use lots of sound deadening material. If you do that you shouldn't have much if any noise.
