Old 07-17-2008, 11:04 AM   #1 (permalink)
Default squeaking wheels???
Not much expirence with the maintainence, I have a loud squeaking noise coming from one of the wheels I noticed last night. it wen't away every time I hit the brakes, back on when I was off the brakes. Is it the brake pads wearing down???> Thanks
tbrisk is offline   Reply With Quote
Old 07-17-2008, 11:14 AM   #2 (permalink)
dsfloyd's Avatar
That would probably be the squeker pad on the brake pad. There is a little metal tab on the bad that squeels when it touches the rotor and goes away during braking. Take the wheel off and look at the thickness of the pads. you should even be able to see the tab. I this is the problem then a brake job is needed.
'60 Series II 88
'04 Silverado 2500 4x4
'02 Altima 2.5 (Hurts less at the pump)
dsfloyd is offline   Reply With Quote
Old 07-17-2008, 11:30 AM   #3 (permalink)
thanks I will check it out.
Old 07-17-2008, 12:31 PM   #4 (permalink)
brian4d's Avatar
Default wait..
Wait, I thought that Disco pads didn't have squealers???
Brian Morgan
I bitch because I can, I can because I live in America.
2002 Discovery SE (Stock - No ACE, No SLS)
1995 Nissan Pathfinder SE (Sold)
1999 Chevrolet Cavalier (Red Bullet)
brian4d is online now   Reply With Quote
Old 07-17-2008, 12:32 PM   #5 (permalink)
dsfloyd's Avatar
If they don't I apologize. Going off of general pads having squeelers.
'60 Series II 88
Old 07-17-2008, 07:40 PM   #6 (permalink)
Stop driving it till you replace your brakes, you are running metal to metal which will kill your rotors.
Atlantic British has a pretty good brake sale going on right now.
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 07:33 PM
L.Rover 16" Wheels & NEW Cooper Tires FOR SALE CustomLRover Discovery Series II 0 02-02-2007 07:54 PM
Steel wheels and Spare tires Hank Land Rover Parts and Accessories 2 09-27-2006 08:15 AM
Wheels (Rims) Militant-Grunt Discovery Series I 20 02-24-2006 07:59 AM
Range Rover/Disco II 18" Mondial Wheels K Kelly Land Rover Parts and Accessories 1 01-07-2005 08:56 AM
