Old 01-26-2007, 10:01 AM   #1 (permalink)
Rover Newb
Default squeling from engine bay under acceleration
its worse when the truck is cold, but under acceleration at what seems from around 1700-2300 rpm it has almost like a belt squeling kind of sound. Do the tensioners go bad, could it just be the belts or something else?
2000 Disco II
1966 911
mnmike is offline   Reply With Quote
Old 01-28-2007, 01:36 PM   #2 (permalink)
did you have a belt recently installed? you can install them wrong and at times they can make noise.
but something could be getting on the belt. coolant perhaps.
Old 01-28-2007, 02:21 PM   #3 (permalink)
Roverhound's Avatar
Take the belt off and rotate everything by hand. Could be an idler pulley seizing.
It just doesn't matter.
Roverhound is online now   Reply With Quote
Old 01-28-2007, 02:31 PM   #4 (permalink)
Both the tensioner and the pulleys fail quite often and will probably need to be replaced.
Old 01-28-2007, 10:36 PM   #5 (permalink)
Rover Newb
the belt wasnt recently changed, but i ordered a new tensioner (dayco #89054) and Ill get a new belt locally too to install.
2000 Disco II
1966 911
Old 01-29-2007, 11:53 AM   #6 (permalink)
Rover Newb
turned out was just a little coolant on the hose from the belt that i replaced. problem solved
2000 Disco II
1966 911
