Well, I changed out my brakes with EBC rotors and pads(green). Flushed out the old brake fluid and went for a break in/test drive. Only about 50 miles into the new setup, but they feel great. Here's the problem, a few miles into it I noticed I had an SRS light.
I read on another thread in here that someone left their rover on over night and that is what caused it. I had my son help me to bleed the brakes, so it took a while, about 30-45 minutes, I would guess. I wasn't really paying attention. I came to my first stop and decided to shut off the disco and restart. The light stayed off but came back on later while I was in town doing some erronds, now it's on all the time. I hooked up my scanner, but nothing shows. Any help is appreciated. Chris |
Chris, if I am not mistaken you can only get rid of the SRS light with a test book at a stealership. I find it odd the SRS light came on. Are you sure it's SRS? I was reading that a drop in voltage could cause the SRS light to turn on.
Abraham 1993 RRC LWB 1995 RRC LWB ![]() I run, play, fix and live Rovers because I choose to. |
Yep, it's the SRS, shining red. I went to turn off the heat/radio during the test run so I could listen for any noices. When I moved my hand, there it was.
Any advice since I don't have a dealership. There is one shop in town that will work on it, but I don't thind they have the LR testbook. I guess I'll call them tomorrow and find out. |
Polish and proud of it.
I have the same problem sometimes , but I think what I have is more of a feature operations.
If I drive and I get up of the seat ( to get my walet out of my pocket ) the light will turn on cause the tranny is in D and I'm rolling while my ars is not on the seat . Sure sometimes I start the truck with out me in it and the light will come on after about 2 min. of the truck running . But under any other times it dose not come on . It only comes on when I'm not sitting in it ![]()
![]() I'm a Proud owner of a vehicle that has a turning Radius of 747 ![]() Check out our Frappr! Myspace ? It dose not mather who votes, only matters who counts the votes _ Krushchew |
Your SRS light didn't come on because of any brake related work you did, it is just one of those weird timely things that happens. If you don't have a dealer near by there are other scanners, like the AutoLogic, that can read SRS codes.
Call Atlantic British at 1-800-533-2210 and ask them to give you the nearest location of a shop with the AutoLogic scanner. Just so you know, when the light is on, it doesn't mean the bag may go off, it just means there is a problem and in an accident the system most likely won't activate. Mike |
#6 (permalink) | |
good , i don't like the air bag . From looking at all the crash tests sometimes it cause more harm then good ( it makes your head to bounce into the B piler with the back of your head ) . Air bag there ( just for the b piler ) would be good . All I need is the seat belt and i'll be fine . I don't need to brake my nose by my own hand like two people i know did . ![]()
Thanks for the help. I called the import shop and they say they have the software to work on it, so we'll see.
I read my Rave manual and from what I can tell the light is on steady because the DCU is getting a no voltage signal from one of the four sources (driver airbag, pass airbag, driver seatbelt tensioner, or pass belt tensioner. I'm sure none of them are cheap, but I haven't found a part on mine that is yet, and my mastercard knows it. |
#8 (permalink) | |
Not Banned
